How high is too high?
Old May 25, 2008 | 09:09 PM
Doobie's Avatar
Max. oil temp. is higher for synthetic than dino oil but which ever you use I believe it needs to get hot enough to burn off or boil out water condensation. 210*F
Old May 25, 2008 | 09:15 PM
Stoichiometric's Avatar
Getting the oil close to 200* is good for the moisture in the oil to evaporate. Water does evaporate at lower temps, especially if you have good vacuum pulling on your crankcase.
Old May 26, 2008 | 10:04 AM
ap2002's Avatar
very true, if its under vacuum it takes less heat to evaporate...
Old May 26, 2008 | 10:25 AM
Slowhawk's Avatar
LS1Tech Sponsor
Sounds like it is in the pan and the hot oil from the turbo is dumping on it.The best place for the sensor is in the corvette location(the plate above the oil filter).
If it was truely pegged at 250+ the oil pressure would drop dramiticly at idle.
Old May 26, 2008 | 04:47 PM
hmatiak's Avatar
Did some looking around also. Found some decent info on a drifting/ricer forum. With their turbo apps, they are keep the oil between 185 and 210. Anything above that to them was a very bad thing. I would say that those temps sound ideal IMO.
Old May 26, 2008 | 05:57 PM
Spoolin's Avatar
GFYS and STFU
OK Great, thanks guys. One good thing is I'm not seeing any drop in oil pressure in the least bit at idle or WOT so that's good. Maybe it's just the sensor's in a bad spot...when I find out I'll post it up.
Thanks again.
Old May 28, 2008 | 09:18 PM
Spoolin's Avatar
GFYS and STFU
So apparently the oil sensor is supposedly where the stock one on the vettes are, right above the oil filter. That location should have the sensor. Its pretty much the only spot to put it. Looks like I might need to get an oil cooler!!
Old May 28, 2008 | 09:47 PM
02sierraz71_5.3's Avatar
those temperatures are normal for oil on average 50 degrees hotter than the coolant
madmann26
Apr 29, 2020 09:17 AM
smok'nZ
Oct 6, 2015 01:14 PM
carid
Oct 1, 2015 09:22 AM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 06:27 AM
