How high is too high?
GFYS and STFU
How many of you are running oil coolers?
I never had an oil temp gauge until recently and now that I have one I'm always starring at it since it's usually pegged out @ 250F if I'm not driving like a 80 year old woman. Even on hot days it'll get pegged just running around town in stop and go.
Ideal engine temp is between 160-180 right? And my radiator and coolant are doing fine keeping my engine temps in that vicinity so I know I'm not overheating and everything is working properly but I'm worried my oil temps are getting to hot and possibly as hot as 500F-600F when I'm in boost alot racing or driving like I stole it.
What's ideal oil temp to run at and who's got oil coolers and how are they working? Or am I just being paranoid?
Man what weight oil are you running?Only reason I ask is because how thinned out is a standard 10w30 getting at those temps?I know a thicker oil won't change your temps but it might give you more protection from having any issues.
I did a little reading on the subject just out of curiosity. Didn't really find anything on turbo engine temps. Most say oil pan temps of 230 is a max. Good synthetics a 300 max. Mind you this is an in pan temp.
Curious where you are taking that temp? IMO an oil cooler would not be a bad idea at all with a turbo setup. That or/and very frequent oil changes.
I dont know what my oil temps get to but i have a large cooler infront of the tranny cooler with a small electrical fan pushing air thru it. since its a sss i have the small oil cooler in the radiator too.
When you reach about 260-280* you are getting into dangerous territory.
Remember wherever the sensor is is not the worst case senario. You could be over 300* somewhere a hot spot resides and cooking small quantities of oil cannot be good for the overall condition of your oil.
Is your sensor f-ed up?
GFYS and STFU
I'm not sure where the sensor is, I'll have to find it but I'm pretty sure Rick didn't put it on the return line from the turbo. At least I wouldn't assume he did. I was running 10-30W and now it's 20-50W per my engine builders advice since it's broken in already. I don't think the sensor is messed up since it seems to read normal at start up and when the engine's starting to warm up and I can see it cool down to 200F on cool days and cruising, but I'll have to see where exactly the temp sensor is at, I hope it's not in the oil pan or I'm screwed!!
Thanks for the advice/help, I'll post back up when I find where the sensor is.
