How do I replace one piston?
Old Apr 8, 2008 | 04:22 AM
CashDudeHomie's Avatar
It's a stock bore 6.0. This is the first time it's ever been opened up. About 65k miles I would guess. What all do you think I should replace?
BTW I'm not exactly sure what you were asking. If you were asking about something else, just let me know.
Old Apr 9, 2008 | 10:29 PM
Dark Halo's Avatar
Just to let you know I have a set of stock LQ4 piston I will get rid of.
Old Apr 14, 2008 | 06:50 PM
What is the proper ring gap? Or are the GM rings properly cut from the factory?
Should I buy a mic and measure the bore? If yes, what are the specifications for a stock piston?
In the first pic, are my pistons dirtier than normal? Do I need to use Seafoam to clean them?
What kind of break in process do I use for the new piston rings? The work starts tomorrow guys!
Old Apr 20, 2008 | 04:28 AM
stock48's Avatar
9 Second Truck Club
What ever happend with this deal? I replaced two pistons on my 6.0l, and swaped a few others to different holes. I found the new pistons were 6-8 grams heavier than the ones I was replacing, so I just lightend them. I got lucky it wasn't the other way around or I would have had to replace all 8. You don't want the new piston to be off more than 2-3 grams from the others, 4g max. That head should be ok, just smooth out the goudge with a cartrage roll, and do a light re surfac. Remember to clean everything really well, and be sure the head bolt holes are cleaned out.
lucas287
31
Jan 12, 2021 06:18 AM
natejk
Nov 15, 2016 08:05 AM
600 horses
Sep 10, 2015 11:01 AM
11MPG
Sep 8, 2015 04:52 AM
xerox17
Sep 5, 2015 01:23 PM
