how concerned should I be about rust on a block
Old Jul 3, 2012 | 05:00 PM
Gadgetized's Avatar
Default how concerned should I be about rust on a block
Well as most know, I smoked my engine. Well I found a 2005 6.0, and was thinking about going bigger. Well the engine is priced right, but the problem is the rust. The vehicle it was in was in a fire. The filler neck is melted, bit that's it. The block is real rusty. We were picking scale off with a screwdriver. It seriously looks like something that was sitting in the ding weeds for 30 years. The engine is a 2005 with supposedly 53k miles on it. I don't mind doing bearings, rings, and gaskets. Is this something that I should get? Or should I stay away because of the rust. Oh, I was able to grab the balancer, and turn it over easily. And I am not sure about the balancer. Would I be able to use my good flex plate off of my 5.3?
Old Jul 3, 2012 | 05:12 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
as long as the rust is outside of the block i wouldn't weary to much i have a 06 LQ9 i got for nothing with a bad oil pump and the block is pretty rusty its from our lovely winters we have. and yes you can use your 5.3 flex plate just make sure you remove the spacer thats behind the 6.0 for running a 80E.
Old Jul 4, 2012 | 12:43 AM
DR132's Avatar
so long as everything that's supposed to be bolted to is it is still bolted to it then you shouldn't have to worry about the insides being fouled up. being able to turn it over by hand is a good sign...did you feel it build compression?
Old Jul 4, 2012 | 12:54 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Rust is not a big deal so long as its not on the inside. They thing you have to worry about is how hot did it get. If you plan on tearing it down then no big deal. If you want to just run it the way it is then you need to look a lot closer...
Old Jul 4, 2012 | 08:52 AM
Gadgetized's Avatar
Thanks for the input guys. I think I am going to go ahead and get it. I will start another thread as I have some questions about gaskets.
Old Jul 4, 2012 | 09:46 AM
Pollo432's Avatar
If ur doing bearings I would suggest you take it to a machine shop. They can check it and clean it up for $100 or so. I bought one that had years of caked on mud with bad bearings. Now it looks real good.
Old Jul 4, 2012 | 07:43 PM
TIM Z's Avatar
11 sec. Truck Mod
Good luck with your new bullet man!
Old Jul 5, 2012 | 03:52 AM
Foxxer's Avatar
Outside = Normal.
Inside = F'd up.
dsbodley
Nov 14, 2015 09:46 PM
gmcyukon
Oct 5, 2015 06:20 AM
old motorhead
Sep 29, 2015 08:22 PM
trxmxzx
Sep 29, 2015 07:42 AM
trevorh1
Sep 27, 2015 08:47 PM
