heads cam swap this weekend
Old Mar 4, 2008 | 05:25 PM
cmiller's Avatar
Default heads cam swap this weekend
im doing a heads cam swap this weekend. 208 cam heads are milled .030 with bigger valves from wcch. is there anything i need to know to do the instal? any tips or tricks i should know about?
thanks chris
Old Mar 4, 2008 | 05:39 PM
sickREDsierra's Avatar
i think there are a few stickies on both subjects, even a sticky on how to install heads without removing the intake manifold.
Old Mar 4, 2008 | 05:40 PM
https://www.performancetrucks.net/fo...d.php?t=363112
Old Mar 4, 2008 | 05:42 PM
http://www.ls1howto.com/index.php?article=23
that will be a $5 fee for doing a search for you.
Old Mar 4, 2008 | 06:19 PM
TarheelZ's Avatar
Hey, good luck with everything, Chris...hope everything goes smoothly and your new-found power puts a big ol' s*** eating grin on your mug!
Old Mar 4, 2008 | 06:20 PM
OnyxSilveradoSS's Avatar
how much time would you estimate for swapping heads?
Old Mar 4, 2008 | 06:42 PM
joshua022's Avatar
I did mine in about 5.5-6hours but thats booking it the whole time at a shop with air tools. I think thats pretty quick though if its your first on ehtan i doubt it'll be quite that quick.
If you've got Lt's get ready for them to **** you off... i could barely get mine out of the way enough to get the head bolts on the side of the heads out and trying to torque them was a lot of fun also. That was the only hard/aggrivating part for me.
Old Mar 4, 2008 | 06:51 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
It takes me about 8 hours to do a h/c swap, but I spend about an hour and a half alone on cleaning the deck of the block and everything, Im very meticulous about that so the motor doesnt burn oil have a coolant leak problem. Just take your time.
Old Mar 4, 2008 | 07:53 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Old Mar 4, 2008 | 08:58 PM
06sierra5.3's Avatar
when i was a tech, guys used to give me **** for spending so much time cleaning up machined surfaces. all it takes is a little piece of **** to clog an oil galley.
i always tape off the intake ports on the heads so i dont accidentally drop somehting down there.
