heads/cam matching
Old Dec 22, 2006 | 02:23 PM
nightrunner's Avatar
Mr. Obvious
Default heads/cam matching
how do you match a cam to a set of heads
lookin at afr205s and a tr220 on 114
are these matched closely or how do you match a heads and cam package
i understand it involves looking at flow numbers from each but i dont know how to read them
afr225s are too big for a N/A/nitrous 6.0 arent they
Old Dec 22, 2006 | 03:20 PM
Ask the guys at Thunderracing about the combo,I'm sure they've done it several tiimes and can give you some good suggestions.
Old Dec 22, 2006 | 03:49 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I always try to hit the best flowing lift number of the head twice in one revolution of the cam. In other words, if the heads hit max flow at .600 I go a little beyond (say .610) in lift so that it hits max flow on the way to peak cam lift, and then on the way back down.
What I try to avoid is a cam that lifts .650 on a head that flows best at .550 and is in the crapper at .650.
Some experst to chat with on this: Richard at WCCH, Roger Vinci at VHP.
Old Dec 22, 2006 | 05:08 PM
Mr. Obvious
thanks for the explanation
so i look and see what the max flow of the heads are at .050 and match that to the lift of the cam at .050 (with a little more as you said)?
or am i way off base?
anyone, feel free to post comments or suggestions
denalircsb
Dec 21, 2020 09:04 AM
OHsixLS3
Nov 22, 2015 07:45 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
Justin87gn
Sep 10, 2015 12:06 PM
