Head Replacement / UPgrades '04 5.3
Old Apr 11, 2012 | 12:24 PM
barthautala's Avatar
Default Head Replacement / UPgrades '04 5.3
So Im pretty sure Im going to find out that I have the Castech head issue. I wont know until tonight.
But besides just swapping out the heads for other stock heads - what other fairly low cost options are out there?
I know about the expensive options.
What else should I do while Im in there?
Old Apr 11, 2012 | 01:15 PM
grey matter 04's Avatar
13 Second Truck Club
depending on mileage i would replace lifters n trays
heads you can do a 243/779 head swap or just replace the 706/862 casting with non cast techs
just depends on your budget
Old Apr 11, 2012 | 01:56 PM
110,000 miles
Looking for a little HP bump. Nothing drastic. If it can be done without an *** ton of work, cool. If not fine and I'll just replace with not castech.
I was reading a little about 243/799 head replacement. I think you did it didnt you? I would have to .030 milled off the bottom right? What else would I need to do the swap?
Old Apr 11, 2012 | 02:02 PM
2000chevysilverado's Avatar
im doing the 799 head swap here soon just need milled .030 new gaskets and that pretty much sums it up besides head bolts
Old Apr 11, 2012 | 02:08 PM
i did the swap milled my heads .040
you must mill them .030 to get back to stock compression because the combustion chamber is 64cc vs the 706/862 61cc
i would replace lifters its only 150 and safe to do so since you right there anyways
Old Apr 11, 2012 | 02:31 PM
Any gains from going .040? I can tune to accomodate but Im already running alot of advance with dual spark tables for premium fuel.
Old Apr 11, 2012 | 04:21 PM
lil bump in compression ratio
depends on how much timing you run may have to alter it some
But i run 28* with my setup on cheap gas...tune accordingly
Old Apr 11, 2012 | 11:53 PM
Vortec350ss's Avatar
Do you have a cam? I have some PRC stage 1 243 heads for only a couple hundred more than used untouched 243's that have been milled down to a 61.5cc chamber already. They come with dual springs and only have about 5k miles on them. If you wanted to do a cam swap these would be a great place to start thats for sure. If you don't have a cam then these heads are definitely overkill.
Old Apr 12, 2012 | 01:36 PM
No I dont have a cam but I could get a cam. PM price on the heads shipped to 49650.
Old Apr 16, 2012 | 07:29 AM
Hi errybody. What about a cam to go with the heads? I see alot of Z06 cams but get laughed at pretty much everytime I mention it.
Im going to take the day and research cams - since I get a damn thing about them. I mean I know what they do and know what the terms mean but I dont know how they affect performance / drivability.
