Head Replacement / UPgrades '04 5.3
Old Apr 24, 2012 | 09:36 AM
  #21
barthautala's Avatar
Exhaust Manifold - no problem bolting this stock exhaust manifold up to the new 243 heads?
Old May 15, 2012 | 01:22 PM
  #22
Anyone else who has done this swap please comment - what about bolting the accessory brackets up? Will this be a problem?
Old May 15, 2012 | 02:09 PM
  #23
nonnieselman's Avatar
Everything will fit no problem..
IF you plan on boost, you should check out the Isky Triple 12. makes good low end and comes alive with boost.
Old May 15, 2012 | 06:15 PM
  #24
dmelvin's Avatar
I've done the 243 head swap. Changed lifters and trays, went with hardened push rods since I changed cam. Milled .030 and used a .040 head gasket to give me 9.9:1 compression. Everything bolts back up fine. If you use the stock .051 thickness gasket, you'll see the stock 9.5:1 compression or extremely close to it.
I also went ARP bolts. You can go with stock replacements, I just find it a pain in the *** to torque them + so many degrees. 3 passes with ARPs in increasing increments of torque up to 80ft/lbs, and done.
Old May 29, 2012 | 02:24 PM
  #25
BigV8's Avatar
I'm also looking at head choices. Did you have to do a tune with 9.9:1 compression, and what lifters and push rods did you use. Thanks
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
sauldgold
Jul 23, 2015 02:15 PM
