Head gasket help
Old Oct 13, 2013 | 12:20 AM
GREENSIERRA's Avatar
Default Head gasket help
hello everyone.
So I decided to change my lifters even tho I don't have any problems with the stock ones just kind of insurance.
So while I have the heads off I may aswell get them shaved .30 and do some valve work. I thought of P&P but don't really want to spend that much at the moment.
correct me if I am wrong but with my L33s stock compression at 9.9 with 799s and then with them shaved .30 I should be at 10.4 compression? lets say I wanted to get around 10.6-10.8 compression is there a head gasket that would allow me to get to that compression?
Also if I go to LS7 lifters I will need shorter pushrods then the 7.4s I run now, what length is typically used with .30 milled, LS7 lifter combos?
I have the heads off now and taking them to my buddy tomorrow and would like to order parts asap to get it back together.
Thanks for any help, Mitch
Old Oct 14, 2013 | 09:55 AM
I need to start ordering parts, any help would be great.
anyone think I would run into PTV problems with this setup and a .40 head gasket?
Thanks, Mitch
Old Oct 14, 2013 | 11:36 AM
I ordered .40 gaskets and will clay the pistons and see what happens.
I also ordered 7.35 pushrods and will check proper length and hope they will work till I can get the right ones in
my buddy is going to also do some porting on the heads while he has them
lsxperformance
Apr 20, 2016 12:17 AM
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
BIGD4504
Jul 28, 2015 11:46 AM
