Guys with low gears and 30" or smaller tires. What CAM do you run??
Old Feb 18, 2013 | 09:36 AM
sleeperlqx's Avatar
Default Guys with low gears and 30" or smaller tires. What CAM do you run??
I'm trying to figure out what type of combos you guys that run low gears and small tires are using. Here is the situation my truck likes to rev. But it's not too bad with me. I know do to fact of my 4.88 gears and 4k stall I blow by the low end. Truck is plenty fast out the hole. I'm trying to pick a cam for my lq9 that will make me have the right power and for this combo and really wake up once the gears start going. Seems like I'll need something that kicks the power hard at 3000 and up. But still produce good power when finally my converter locks around 2400-2700
What cam combos are some of you people running with similar gears and stall?
Old Feb 18, 2013 | 08:57 PM
04Hall's Avatar
Something in the high 23x range would be my guess.
Old Feb 18, 2013 | 09:00 PM
04Hall's Avatar
It wouldn't have much of a low end at all but 4000 stall and those gears should be good for that big of a cam. I would call a sponsor to the right and have them spec you one. Curious to see what they say
Old Feb 19, 2013 | 07:00 AM
dirt track racer 81's Avatar
Old cam was 244/248 .612/.615 112+2 new cam is 251/267 .623/.623 115+6. Converter is an Fti 3200. 4.56 gears.
Old Feb 19, 2013 | 10:44 PM
sleeperlqx's Avatar
what size tireS?
I really dont need lowend. I really want alot more mid and top end power. And I feel like I need or have a narrower powerband, as to say between 3000-6,500rpms. I mostly hover at 3k all the time if unlocked. But power comes on hard over 4k.
Really confused on the cam. Im just gathering info now to what some other combos are.
Old Feb 19, 2013 | 11:17 PM
295/40/20 28-10.5-15 slick
Old Feb 20, 2013 | 03:05 PM
Camin00's Avatar
Comp Cams XTREME XE-R XER287HR 238/240 .605/.609 112 LSA
RPM range 2800 - 7200
I have a buddy with single cab 6.0 cnc ported/milled 243s ^ this cam
He has 4.56 and 3600 stall truck is scary scary scary haha
He set his mild built 4L60e to shift around 6800-7000 rpms to be "safe" < the thing is going to blow sometime this year I'm predicting
Picking a cam is the most difficult decision but in the end cams that are within the same range of specs as other will pretty much perform the same give or take 5-10 hp which is not going to be that noticeable.
Old Feb 20, 2013 | 08:04 PM
1/4milelarry's Avatar
224/228/ .580 114lsa 3600yank 4:30's on 28x10 on 16in rims. ran a 12.9. on stock heads, stock intake stock everything else but bolt ons and injectors...
truck pulled hard 3000-6000rpm wish i would have gone 30x12 on the 16in rims. needed more bite/ more wrinkle and the taller tire woulda helped my top end a tad bit
Old Feb 21, 2013 | 10:14 AM
DTHPROOF's Avatar
221/226 114lsa
Yank SS3600
4.56's
30" street tires/30"slicks. Feels awesome!
Old Feb 21, 2013 | 08:17 PM
sleeperlqx's Avatar
Ok so from what I gather. I may use a cam that was originally speced for me. Seems like you guys are runing decent size cams.
The 1 if was told to roll was a 228:232 iirc. I will check specs when I get home.
