got it down to 2 cams help me decide..
Old Jul 20, 2011 | 06:51 PM
silverado2000's Avatar
Default got it down to 2 cams help me decide..
CURRENT MODS
6.0
243 heads
1.75 magnum roller rockers
mahle flat top piston part#(LS1340030F04)
comp 918 springs(i plan on getting new springs from yall)
current cam 218 222 .544 .544 lsa113
42# injectors
pasetter lt's
cai
yank 3600 stall
built 4l60e
3.73 gears
I asked the guys over at texas speed what cam they recommended for my set up and the said the Torquer v.2 or v.3.
I trust what they said i just cant decide between the to the cams as they are very similar. v.2 232/234 .595 .598 v.3 231/234 .643 .598 both will be on a 112lsa.
What do you guys recommend, im going for a ***** to the wall fast truck thats my only goal
i want to order the cam and springs to night so lets hear what yall think
Old Jul 20, 2011 | 08:48 PM
zero2sixT's Avatar
From what I understand, the t3 is supposed to be a revised version of the t2. T3 is supposed to have a faster ramp rate.
I was going to run a t3 in my 6.0. My friend had a 230/236 .581/.581 on a 114 custom comp laying around his shop. I went with that instead.
Old Jul 20, 2011 | 08:54 PM
05gmcsierra's Avatar
if ur heads arent worked i say stay under the 600 lift. that v.2 cam will run really nice on ur truck imo
Old Jul 20, 2011 | 10:23 PM
06murder's Avatar
i say v.2!
Old Jul 20, 2011 | 10:49 PM
Mangled03gmc's Avatar
Baltimore Whore
If your stock 243's then the first one will do well.. As for what lobes the cams are ground on, I am not sure.. A super aggressive lobe will wear out springs faster..
Old Jul 20, 2011 | 11:09 PM
slowlsx's Avatar
Get tue converter restalled to a 4000 and go more aggressive on the cam! You will end up doing it anyway might aswell do it once
Old Jul 21, 2011 | 10:09 AM
Going with the v.2, and after this cam, springs, and 4" exhaust I'm
Done with the truck for a while. Ive been looking at a few c6 and c5 zo6 so the truck will be on the back burner it I find a vet. I will keep everyone updated on the cam swap progress though.
Old Jul 21, 2011 | 10:16 AM
Sales2@Texas-speed's Avatar
Former Vendor
I agree and prefer the V2 for the stock headed combos. it's not that the V3 doesn't make a bit more power, because it does. It's just the slight power gains on a stock headed combo from that extra lift is very minute, and will wear out springs a bit faster so I like the lower lift on these.
Now with a ported head that doesn't back-up until well after .650" lift, the TorquerV3 would be my choice, hands down!
Old Jul 21, 2011 | 05:54 PM
Just ordered the v2 how long tell i get it
Old Jul 22, 2011 | 01:08 PM
Former Vendor
Just looked it up, and a couple days. We ran out of that v2 on the 112LSA somehow so we're having Comp grind it with a rush and they'll ship it directly to you!
