fluidampers? any one tryed those ?
Old Feb 9, 2013 | 05:48 PM
sand man's Avatar
Did you find any Automotive Race teams using them religiously???
I have been reading and searching for 6 hours now
really didnt find any race team related info about what or why
what I found is that the fluidamper isnt trusted as much as the ATI
most would go with ATI just for that reason
also , I have been looking at alot of high HP pojects on LS motors , I have yet never seen one with a fluidamper . 90% have the ATI and 10% run the stocker
Im not reving my engine to the moon , I just want a safe 6500-6800rpm capable motor
Im really lost
Old Feb 9, 2013 | 06:58 PM
Mangled03gmc's Avatar
Baltimore Whore
All in all you do not need it, spend money else where. No reason to be lost..
Old Feb 9, 2013 | 07:03 PM
1FastBrick's Avatar
Custm2500's Rude Friend
As I mentioned before while the theory sounds good, they have proven to be troublesome for alot of people.
Alot of people have snapped the crank snout off using that type of balancer.
That is the reason you don't see them used alot in racing applications.
The sudden on and off of the throttle is no match for the fluid inside.
Old Feb 9, 2013 | 07:43 PM
1FastBrick's Avatar
From ATI's site.
"Viscous fluid dampers are sealed and you don’t know you have problem until it’s too late. The inertia weight can become fixed (locked) by bearing failure or, more commonly, from the silicone turning to a solid mass. Your first warning of damper failure will probably be a broken crankshaft resulting in the replacement of your damper AND the engine. Viscous fluid dampers are not only ineffective but are actually detrimental at high RPM's."
ATI Damper Technology
It's for you to decide but you don't see them used in Nascar or NHRA.
In fact I have heard they were band for use in Nascar but not sure how to confirm that.
Old Feb 10, 2013 | 11:27 AM
sand man's Avatar
OK , I can get the ATI for 210$ go or no go ?
consedring the next
this motor will be NA for a while so 500~550 flywheel hp
and in a year Ill get into the 700 and grow to about a 1000 finaly using a turbo kit.
the concept behind the dampers is different from harmonic balanncers
the balancers are used with non-internal balanced motors, while the dampers are used with all motors to decrease or eliminate the vibrations , these vibs have a peak @ a certin RPM typicly 5000~RPMs wich harm the engine the most.
I know alot of guys here don't run them , but I really want to protecet my investment in the motor in any way possible, I wouldent hold off 200-400$ if its gonna make it safer for the 5000$+ motor.
not to mention I lost a 408ci short block already in less thean 530 miles
Old Feb 10, 2013 | 11:37 AM
03sierraslt's Avatar
I think you are over thinking it, you are not building a 7K+ rpm race motor. Run what you have, it should be just fine.
Old Feb 10, 2013 | 11:57 AM
1FastBrick's Avatar
If I am not mistaken the ATI is rebuildable while the Fluidampner is not, so if you bump it, drop it, or what not it's junk.
The factory balancer on these cranks has been sufficient for most stuff. If you want to invest in something buy something that can be serviced.
Your bearing issue was due to the machined crank tolerances. they are usually out of tolerance toward the out side edge of the journal. Although it is not often discussed it is common. A lot of those cranks are manufactured and finished ground in china. There brought here, inspected, and re packaged. Some companies do additional machine work and add there mark's to identify it as there own specific product.
Old Feb 10, 2013 | 12:56 PM
sand man's Avatar
its a compstar crank , wish I went with the DS to have a peice of mind , but I didnt have the 700+ upgrade cash
thanks , Ill stick with a stocker
GMCtrk
Jan 27, 2016 06:47 PM
murderedSS
27
Oct 12, 2015 11:13 AM
jtphelps289
Sep 29, 2015 12:00 PM
MA$TER_E
Sep 9, 2015 03:14 PM
turbo truck
Sep 2, 2015 09:58 PM
