Few questions for a friend
Old Nov 24, 2008 | 07:13 PM
LowNSlo02's Avatar
Default Few questions for a friend
Hes looking at building a N/A 6.0 for his RCSB chevy. Right now hes got a 5.3 in it with all bolt ons and a built trans with a true trac and 3.73s in the rear. Hes looking for a little more... So he has a 6.0 block and is going to be puttin flat top pistons out of a LS2 i think? What kinda heads would you recomend for his motor? just keep the stock 317's or go with something else?
Any help is appreciated!
thanks
Old Nov 24, 2008 | 07:20 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The stock 317's breath very nicely, unless he wants to spend $3K on heads I'd leave'em.
Old Nov 24, 2008 | 09:40 PM
dlt76028's Avatar
get some cnc machined 243s they will flow a ton and they will raise the compression.
check out some sponsors like TSP ----------->
their stage one are $1100
http://www.texas-speed.com/shop/item...d=649&catid=40
Old Nov 24, 2008 | 10:05 PM
dirt track racer 81's Avatar
even stock 243s would go nicely with that.. they flow the same as the 317 but have 64cc chambers vs 317s 71cc chambers..with the ls2 pistons and 243 heads you would basically have an iron block ls2
Old Nov 25, 2008 | 11:08 PM
LowNSlo02's Avatar
so he could put those pistons in it with the 243 heads and some stock gaskets and be fine compression raito wise? would it help to bump it up a little bit? Hes looking to do a little cam, and some tuning with all his bolt ons and see what happends...
2500ZL1
Jan 25, 2016 06:30 AM
Goat's ss
Jan 3, 2016 06:28 PM
5.3Caprice
Nov 7, 2015 08:56 PM
USMCvet0311
Aug 1, 2015 07:45 AM
