View Poll Results: Who should tear apart my mistake
Me
41.67%
The machine shop
8.33%
Put it back together and dump the clutch
50.00%
Voters: 12. You may not vote on this poll
Engine tear down DIY or Shop?
Old Jun 24, 2020 | 07:37 PM
dantheman1540's Avatar
Default Engine tear down DIY or Shop?
Just now getting to my 6.0 that I think I spun a bearing or had a lifter fail. Should have it out next week and I'm torn between tearing it apart myself to find the point of failure or just taking the entire thing to a machine shop and have them disassemble it since they will be the ones rebuilding it. Kinda seems like a stupid question but I'd like to know for sure what the point of failure is since its likely my fault. I had planned to disassemble it myself but a few bromigos told me to just let the shop do it.
Old Jun 24, 2020 | 08:03 PM
ZO6Ted's Avatar
Depends on your work load and income. Also in my case age and pain lol.
Old Jun 24, 2020 | 08:19 PM
Time is not an issue I'm going to take it slower this time.
Money (within reason) is not an issue if there is a benefit to the new rebuild. Not sure what that would be exactly.
Physical ability is not an issue but mental capacity might be
Old Jun 24, 2020 | 09:09 PM
terravast4's Avatar
Tear it down. If you remove main caps and pistons label them
Old Jun 24, 2020 | 09:21 PM
RB04Av's Avatar
5 Year Member
Do it yourself. Take pictures, keep everything in order, document what's there, etc.; so that whatever info is contained in it, is preserved. But by doing it yourself, YOU know what's messed up (or not, up to a point) and can discuss intelligently with your machinist what you want done. Do it slowly and meticulously so you don't miss anything.
Old Jun 24, 2020 | 10:33 PM
arthursc2's Avatar
Do it yerself
and dump the clutch. Always dump the clutch
Old Jun 25, 2020 | 07:03 AM
firebladeJJ's Avatar
Do half of it yourself. I pulled mine apart, took the block and rotating assembly to the shop, had them clean and inspect everything and assemble the rotating assembly then did everything else myself. I have a lot of tools and know how, but there is some stuff best left to a good engine shop.
Old Jun 25, 2020 | 07:42 AM
arthursc2's Avatar
Do the left bank yourself and let the shop do the right bank lmao
Old Jun 25, 2020 | 08:07 AM
Thanks for the responses
I think I will end up doing it myself, seems as though there's no real benefit to having them do it. I'll be sending them everything I think is salvageable anyway, I hope the block and heads are alright.
Old Jun 25, 2020 | 08:32 AM
madmann26's Avatar
Get a number punch set for the main caps or a center punch will do.
Take it slow.
