Dynamic Compression Ratio How much is to much?
Old Feb 14, 2013 | 07:25 AM
Yohns Kustom Fab's Avatar
Formerly classic_speed (2015-06-02)
Default Dynamic Compression Ratio How much is to much?
I think I may be a bit too high...
Shooting for a 93 octane on this engine.
The Static Compression is 12.14:1
The Dynamic is 9.5:1
Ive seen a few trucks on here running 12:1 with boost on top of that but they had a lower DCR.
Any opinions/ first hand experience?
Old Feb 14, 2013 | 12:32 PM
53bowtie's Avatar
Seems like I remember somewhere around 8.5:1 being the max recommended with 93. Maybe someone else will chime in to confirm.
Old Feb 14, 2013 | 01:55 PM
chevrolet all the way's Avatar
correct. usually no one runs over 8.5 and thats still pushing it... what in the world are your cam specs??
Old Feb 14, 2013 | 04:16 PM
smokeshow's Avatar
Mod with training wheels
Dynamic CR aside, why would you build a 12:1 static CR engine for 93 octane?
Old Feb 14, 2013 | 04:28 PM
Because 13:1 would be to high....
Old Feb 14, 2013 | 04:30 PM
219/227 607/614 112
Old Feb 14, 2013 | 04:34 PM
smokeshow's Avatar
Whenever I have someone asking for a tune with a high compression engine like that and they are wanting to run pump gas, I always recommend dual tunes. Get some decent mileage on pump, hold back the timing (a lot) and don't beat on it too much. Then when you want to race, swap ECMs to a race gas or E85 tune and put it on kill mode.
Old Feb 14, 2013 | 04:47 PM
Yeah that's what I thought. I can pull timing to make it work.
Old Feb 14, 2013 | 04:49 PM
I have e85 in my area so that's also an option
Old Feb 14, 2013 | 04:52 PM
GMCtrk's Avatar
The question would be much better asked on LS1tech. Personally, I would have built the motor 14:1 and run it on E85.
