Dynamic Compression
Old Mar 15, 2010 | 06:31 PM
05HD1500's Avatar
Bump! still interested in figuring this out guys...
Old Aug 7, 2012 | 05:44 PM
05HD1500's Avatar
Chirp Chirp
any one ever find out the intake closing events yet?
Thanks!
Old Aug 7, 2012 | 08:31 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Why don't you call a cam company and ask???
Old Aug 8, 2012 | 05:33 PM
05HD1500's Avatar
What cam company would you recommend i call to get the intake closing point for a stock LQ4 cam?
Old Aug 8, 2012 | 09:10 PM
SCOTT_A's Avatar
I was curious of this and figured it out using the Wallace Racing Dynamic Compression calc from page 1 in the thread. Dynamic compression ratio of a stock LQ4 is 8.89:1. I used a 4" bore, 3.622" stroke, 6.098 rod length, 9.4 static compression, intake valve closes 34 deg ABDC, 0 boost pressure and 0 altitude (sea level).
Old Aug 8, 2012 | 09:23 PM
SCOTT_A's Avatar
The intake valve closing ABDC that I used was from Hot Rod magazine (NOV 2007) and is @.050" lift. I believe the information we need is @.006" lift. I don't have that number, so my calc above is inaccurate.
Old Aug 8, 2012 | 09:50 PM
SCOTT_A's Avatar
I found the intake closing ABDC @ 0.004" to be 87 degrees, which yields 6.06:1 dynamic compression. Thats exactly what GMCtrk said it was. "Down in the *******".
Old Aug 9, 2012 | 09:07 AM
05HD1500's Avatar
wow!! thank you, just out of curiosity, where did you find that at so that i cam look for future info?
ya that is pretty low , i bet a fast ramp rate cam, even with more duration will yeild a higher dynamic. good info to know.
Old Aug 9, 2012 | 09:50 PM
SCOTT_A's Avatar
I googled "lq4 cam specs ABDC "
I found a Super Chevy magazine article with a complete list of cam specs.
Old Aug 10, 2012 | 10:27 AM
05HD1500's Avatar
YOUR THE MAN!!!!
for those who want to know they list most of stock cam timing events toward the bottom:
LS Engine Performance - Super Chevy Magazine
walledition
Feb 24, 2026 03:27 PM
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
