Does anybody have a clue why?
Old Jun 14, 2006 | 05:53 PM
  #31
5.3 racer's Avatar
before i replaced the chain this time, i'd pull the cam out out and check the cam bearings. shine a flashlight into the cam tunnel and look for wear and make sure the oil feeds are lined up. you could be losing oil pressure to one of the bearings causing the cam to seize.
Old Jun 14, 2006 | 06:09 PM
  #32
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The journal on the cam would be gaulded so bad it wouldnt even be funny if the cam was seizing and if it was it would spin a cam bearing and lose all oil pressure. He needs to look elsewhere IMO.
Old Jun 14, 2006 | 06:51 PM
  #33
5.3 racer's Avatar
you're most likely right, but with breaking 2 chains most likely because of a bind problem it doesn't hurt to check.
Old Jun 15, 2006 | 09:58 AM
  #34
Richard@WCCH's Avatar
FormerVendor
95% of the time engines suffering from timing chain failures are caused by defective or improperly installed crank dampers. In your case the failures occured with the factory assembled engine and reinstalled assembly, so I would rule out improper assembly. The likeliness of 2 defective timing chains is extremely remote. A defective crank damper pulley transferes harmonics to the timing chain and is almost always the cause for chain failure. Defective dampers will also cause oil pump pickup failures on the older gen SB Chevys and BB Chevys. Other related symptoms are front and rear crank bolts and converter bolts coming loose and falling out.
Don't spend a lot of time analyzing the front pulley on your engine, just change it when you replace the timing chain and move on.
Good luck.
Richard
Old Jun 15, 2006 | 11:17 PM
  #35
La Chochita's Avatar
Thanks guys..........today the FedEx came to my house to drop off my headbolts and the Ls2 timing chain set, but my mom wasan't home so I have to wait to tomorrow.
So Richard, you're saying that it might be that my pulley is a little unbalanced?
Old Jun 15, 2006 | 11:31 PM
  #36
Originally Posted by AintNoHo
It sounds to me like the cam is walking allowing the chain to land on a timing gear tooth. Where are the marks on the chain? Engine side would say it's walking forward. I don't know LS engines but on mine I'd say the cam button is missing, all the shims fell out, or the cover is badly worn. Radiator-side chain marks say its walking backward. The brass cam plug in the back of the block may have been installed wrong. Maybe this will make sense to one of the LS guys.
I couldn't tell which side of the chain was facing what side cuz when I opened the timing cover, the chain was at the back of the cam gear hugging it from behind broken so I just pulled it out.
Guys, you know what the messed up part was? This happened right in front of a guy that I passed by his house and reved at him,.....he must have been laughin his a$$ off my truck . I never do that but this guy does the same thing every time he passes by my house so I went and did the same to him........ain't that a B!t(#.
Old Jun 16, 2006 | 11:35 AM
  #37
FormerVendor
No, it's not a balance issue. It's the pulley's inability to dissipate the torsional (or twisting) energy that runs back and forth along the crank. Replacing the pulley is the only sure way to eliminate the problem from occuring again.
Good luck,
Richard
Old Jun 16, 2006 | 11:47 AM
  #38
rgvsierra's Avatar
oh well it'll just get stronger now.
Old Jun 16, 2006 | 12:23 PM
  #39
86MC_SS's Avatar
Hmmm never ever heard of this happening on an LSx engine. When you solve the problem please post what was wrong.
Old Jun 18, 2006 | 08:35 AM
  #40
Dirty Dave's Avatar
You need to pull the cam out. You may have a lifter with a bad wheel. When the lifter starts to wear out the lifter will pit then the cam will wear out and leave a dip in the lift side of the lobe. When the lifter hits the dip the chain gets jerked after a while the chain will break. I have seen this in many gm I4 engines and ford 3000 v6. Mileage doesn't matter it has more to do with metal quality and the hardening process. Good luck!!
