Does anybody have a clue why?
#21
don't think ou need the gears you cn order them but you don't need them to run the ls2 chain. but with whats going on i would order a new gears for top and bottom if cheap. just to make sure there is nothing wrong with them.
#22
Originally Posted by gonzo 6.0
Sounds like no matter what kind of chain you install it will keep breaking until you figure out why,I was thinking like the other guy mentioned a bad main thrust bearing,what can cause that is the torque converter balloning and pushing the crank forward,balloning converters are sometimes do to a restricted trans cooler in the radiator.Check your crank end play.
I really do think that in order to break that chain, you are gonna have to have those sprockets out of alignment. Got any pics of the chain itself? That may give a little insight to how the damn thing is breaking.
#24
Originally Posted by litreddevil
if would had broken 2 timing chains i would be putting a double roller timing i think u have to get a new front cover and shim the oil pump not sure.never had that problem
#25
Man I wish I knew why this happened......I saw that the chain had a couple of half links missing like if it was starting to break from different parts. I checked both the cam and bottom gear to see if it had side markings like if the chain was operating in a crooked kind of way but it seems normal. And the bottom gear was all the way in. If I could post a pic of the chain but I don't have a scanner....damn. This is just weird.
#26
#28
12556582 $16.86 crankshaft sprocket
12586482 $27.75 chain
12576407 $22.62 camshaft sprocket
getting your homework done for free ......priceless.
go to gmpartsdirect.com type these in your good
#29
thanks...
