dod cam
Old Dec 15, 2009 | 02:38 AM
CAPO's Avatar
Default dod cam
hi guys
DID anyone tried a DOD CAM, I HAVE 2007 envoy denali 5.3L , i had HOB kit installed ,
now 455 whp , the engine is stock i would like to put a cam in it , also i dont want to loose the DOD , beside the hard work in convertion , so i need DOD cam , some said would,nt give anything ,
i hope some one tried the cam on dod LH6
Old Dec 16, 2009 | 12:53 AM
CAPO's Avatar
top of the thread
Old Dec 16, 2009 | 03:50 PM
Tootall's Avatar
https://www.performancetrucks.net/fo...highlight=mast
completely off topic
Old Dec 16, 2009 | 04:16 PM
Phantom's Avatar
11 Second Club
there is a company making DOD cams...lemme find my mag real quick
my bad...its a company called MAST that has VVT cams
Old Dec 16, 2009 | 11:33 PM
CAPO's Avatar
i know the companys sell these cams ,
i,m asking if anyone tried these cams, any sign of gain in hp an tq
Old Dec 17, 2009 | 12:24 AM
CAPO's Avatar
thanks for the post , but all 3 threads talking about VVT L92 with cam phaser , and thats not applied to my LH6 , i have DOD ,,, i hope some tried the DOD cam , they claim 35 HP of gain , a guy from east cost said pull shift !!
Old Jan 9, 2010 | 08:01 AM
2wd1500Crew's Avatar
Originally Posted by CAPO
hi guys
What is HOB.? And you say you got 455 whp from it.? Do you have that now with the 5.3.?
Old Jan 9, 2010 | 09:04 AM
CAPO's Avatar
HOB= house of boost procharger P1-SC1 kit for V8 envoys and trailblazer,s
and yes i have it now with 5.3L ,the engine is stock this why i need a cam to get more power....
http://forums.trailvoy.com/showthrea...charger&page=3
http://www.youtube.com/watch?v=gb-ja...layer_embedded
Old Jan 9, 2010 | 02:55 PM
Tootall's Avatar
I think that you're confusing DOD with VVT.
DOD - Is in the PCM (tuning). It can be enabled or disabled
VVT is a different cam shaft with groves in the bearing races of the cam. There's also a cam phaser infront of the cam.
Old Jan 9, 2010 | 03:07 PM
CAPO's Avatar
this is what i said , i have DOD not VVT , pcm shut off the 4 cylinder,s fuel ,spark and the valves , vvt pcm control the cam by phaser , icant remmber how many degrees maybe from 20 to 70 deg resulting in good MPGs
