dod cam
hi guys
DID anyone tried a DOD CAM, I HAVE 2007 envoy denali 5.3L , i had HOB kit installed ,
now 455 whp , the engine is stock i would like to put a cam in it , also i dont want to loose the DOD , beside the hard work in convertion , so i need DOD cam , some said would,nt give anything ,
i hope some one tried the cam on dod LH6
hi guys
and yes i have it now with 5.3L ,the engine is stock this why i need a cam to get more power....
http://forums.trailvoy.com/showthrea...charger&page=3
http://www.youtube.com/watch?v=gb-ja...layer_embedded
DOD - Is in the PCM (tuning). It can be enabled or disabled
VVT is a different cam shaft with groves in the bearing races of the cam. There's also a cam phaser infront of the cam.
this is what i said , i have DOD not VVT , pcm shut off the 4 cylinder,s fuel ,spark and the valves , vvt pcm control the cam by phaser , icant remmber how many degrees maybe from 20 to 70 deg resulting in good MPGs
