Cylinder head questions
Old Apr 21, 2006 | 01:48 PM
Zick's Avatar
Default Cylinder head questions & DCR
What's the max amount you can mill off a 317 (6.0) head? Also, is it .010 or .015 that you have to remove in order to lower the CC by 1 point?
Just wondering if there is any way to reach 66 or 68cc on a set of 317s?
Here is my dilemma;
I'm trying to get the best DCR ratio I can with the cam that I have. This is going to be a stock LQ9 with a TR230/224 111 cam.
Here is what I'm coming up with.
230/224 w/ 317s
DCR Ratio
72cc & .045 = 7.8 DCR <--- Obviously too low
68cc & .045 = 8.16 <--- Thinking about this, but is this still too low?
68cc & .040 = 8.26
66cc & .045 = 8.35
66cc & .040 = 8.46
SC Ratio
72cc & .045 = 10.36
68cc & .045 = 10.86 <--- *
68cc & .040 = 10.99
66cc & .045 = 11.13
If I can’t get the 317s to 68cc, my next option would be to go with LS6 heads correct?
Last edited by Zick; Apr 21, 2006 at 03:02 PM. Reason: Tried to edit title but didn't work. :(
Old Apr 21, 2006 | 03:53 PM
Zick's Avatar
BTW, here is my cam card in case anyone would like to double check my work.
Old Apr 21, 2006 | 04:27 PM
Keith's Avatar
Pretty sure that the 317's are a large chamber version of the LS6 and LS2 heads. You might be better off going with a LS6 or LS2 heads. Those are 62-64cc chambers, right? You could polish the chambers and maybe remove a little material to end up at 66-68cc's
Old Apr 21, 2006 | 04:30 PM
Zick's Avatar
Yeah I just got this info from Rich at WCCH
Milling the heads .035" will get the chambers down to 68cc. It would take a milling of .045" to get the chambers to 66cc.
So it sounds like maybe getting some LS6 heads might be the way to go or else I'll be milling a lot and throwing off the Geometry.
Old Apr 21, 2006 | 06:08 PM
02sierraz71_5.3's Avatar
Here is my dilemma;
230/224 w/ 317s
DCR Ratio
68cc & .040 = 8.26
66cc & .045 = 8.35
66cc & .040 = 8.46
SC Ratio
72cc & .045 = 10.36
68cc & .040 = 10.99
66cc & .045 = 11.13
You can mill however much you want its just a matter of p/v clearance with some cams. Where did you get those specs?
They seem to relate the size CC and then the amount to mill to reach desired compression but it doesnt say what motor its on, deck height, piston dish etc... all that info is need
DCR is mainly concerned with the intake valve closing on the comp. stroke so its sset by the cam, you need to know valve events to figure that
Old Apr 21, 2006 | 06:33 PM
Keith's Avatar
Whats the deck height of the LQ9?
I know some LS1's have their pistons abouve the deck. Same thing with the LQ9?
I'm trying to run the numbers in the DCR calculator I have.
Old Apr 21, 2006 | 09:21 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Yep. -.008 piston DH for LQ9
Old Apr 21, 2006 | 10:46 PM
Zick's Avatar
I said its going onto a LQ9. I already entered in all the info needed to find DCR and that is what I listed.
I've got a DCR calculator and everything I need to know for it is listed on the cam card.
Old Apr 21, 2006 | 10:47 PM
Zick's Avatar
I put -.007 so I wasn't too far off.
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
sauldgold
Jul 23, 2015 02:15 PM
jmarkway
Jul 18, 2015 09:23 PM
