crankshaft
Old Nov 26, 2007 | 10:32 PM
xdanny510x's Avatar
Default crankshaft
iknow this might be a dumb ? butcan i use a stock crankshaft from a 5.3 into a 6.0 block?
Old Nov 26, 2007 | 10:45 PM
thunder550's Avatar
High on diesel fumes
Yes. The 5.3 and 6.0 crankshafts are all the same specs AFAIK.
Old Nov 26, 2007 | 11:54 PM
TravisH's Avatar
I thought the 6.0 had a longer stroke? Mabye it was the 4.8?...
edit: the 4.8 had a shorter stroke. but there is a wide flange and narrow flange 5.3/6.0 crank.
http://www.automotiverebuilder.com/ar/eb040538.htm
Old Nov 26, 2007 | 11:58 PM
Spoolin's Avatar
GFYS and STFU
Only difference to my knowledge between the 4.8 and the 5.3 is stroke, which would mean different cranks between the two. The Bore is the same on the 4.8 and 5.3 AFASIK.
Old Nov 27, 2007 | 12:00 AM
PathfinderJr's Avatar
4.8 stroke is like 3.26". The 5.3/5.7/6.0 stroke is 3.6x" I think.
Old Nov 27, 2007 | 02:05 AM
xdanny510x's Avatar
so then its the same crank for the 5.3 and 6.0 then right?
Old Nov 27, 2007 | 06:43 AM
silver-mod-o's Avatar
Hunt&Fisherator
5.3/5.7/6.0 same same same....
Old Nov 27, 2007 | 04:53 PM
Red04Silverado's Avatar
Sorry if this is off topic, but could you put a 5.3/5.7/6.0 crank in a 04 4.8L with a 5spd? I know that GM made a wide and narrow flange.
Old Nov 27, 2007 | 07:44 PM
Spoolin's Avatar
GFYS and STFU
If you did I think you'd turn that 4.8 into a 5.3...change the rods though or you'll put the pistons through the heads I would think.
Old Nov 28, 2007 | 05:02 PM
I like the idea of turning my 4.8L into a 5.7L. I wanted a forge crank, but I dont know if I have a narrow or wide flange.
5.3Okasai
Mar 9, 2022 01:07 PM
sTNT971
Sep 26, 2015 04:22 PM
Forcefed81
Sep 8, 2015 10:02 PM
4B11T
Jul 13, 2015 03:48 PM
mjgjr72
Aug 4, 2005 08:39 PM
