Crank timing gear
Old Jul 29, 2007 | 02:39 AM
Default Crank timing gear
How do you get the crankshaft timing chain gear off? Is there a special tool or what?
-David
Old Jul 29, 2007 | 02:50 AM
jblack6527's Avatar
I would assume a standard gear puller would work, but I'm not 100% sure.
Old Jul 29, 2007 | 07:48 AM
Yogi Bear's Avatar
Just use the same 3-jaw puller that you used to get the harmonic balancer off. It comes loose pretty quick and will then slide off.
Old Jul 29, 2007 | 10:56 AM
moregrip's Avatar
what a rush!
there is a special tool but a 3 jaw works just as well
5.3Okasai
Mar 9, 2022 01:07 PM
thunder550
Oct 8, 2015 04:53 PM
chevyl33
Aug 24, 2015 08:21 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
GreyChevy
Jul 7, 2015 08:57 PM
