Cracked heads (317's)?
Old Jul 11, 2012 | 06:16 AM
Hivelocit's Avatar
Default Cracked heads (317's)?
Stock 2005 6.0l engine with 70,000 miles, pulled the heads off and took them down to a head shop in town to be cleaned and refreshed. On visual inspection everything looked great, shop calls me next day to say both heads have the start of a hairline fracture between the valves. They weren't pressure checked mind you just looked at... Haven't been there to see what they are talking about yet, but is this common? I know head bolt locations are prone to cracking, but unless the seat pressure was high that area to me seems rare, unless overheated? Should I **** can the heads and buy a new set for cheap, because this will eventually become a boosted block, and I don't want something small to become something worse?! Might take the heads somewhere else for a second opinion.
Old Jul 11, 2012 | 07:44 AM
AndysC3's Avatar
I have a set of 317s that came off my lq4 with about 71k miles if it comes to that. Hope you get of fixed.
Old Jul 11, 2012 | 07:48 AM
Hivelocit's Avatar
Thanks! They are pretty easy to find, but keeping my fingers crossed for now!
Old Jul 13, 2012 | 07:22 AM
Foxxer's Avatar
Weld it :p GL on the fix.
Old Jul 13, 2012 | 09:56 PM
Hivelocit's Avatar
So went to check on the heads, and the machinist was able to massage the crack out of the metal. Said it was just a hairline fracture! Nice! He suggested brass Valve stems, anyone here use these?
Old Jul 13, 2012 | 10:07 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Brass valve stems??? Do you mean brass Guides???
Old Jul 13, 2012 | 10:10 PM
Hivelocit's Avatar
Lol... Oops guides!!
Old Jul 13, 2012 | 10:23 PM
1FastBrick's Avatar
Is there something wrong with the originals???
Old Jul 13, 2012 | 10:28 PM
Hivelocit's Avatar
Said they were worn enough to replace and said it was only a dollar more for brass, which he then said were easier on the valves than the originals. Which I guess brass would be, but I've never used them.. Good idea?
Old Jul 13, 2012 | 11:29 PM
midevil1's Avatar
I don't see factory guides worn out with 70K on them. I have seen ones with 170K good to go another 100K... The machine shops will take every penny from you if you let them.
