Cracked heads (317's)?
Stock 2005 6.0l engine with 70,000 miles, pulled the heads off and took them down to a head shop in town to be cleaned and refreshed. On visual inspection everything looked great, shop calls me next day to say both heads have the start of a hairline fracture between the valves. They weren't pressure checked mind you just looked at... Haven't been there to see what they are talking about yet, but is this common? I know head bolt locations are prone to cracking, but unless the seat pressure was high that area to me seems rare, unless overheated? Should I **** can the heads and buy a new set for cheap, because this will eventually become a boosted block, and I don't want something small to become something worse?! Might take the heads somewhere else for a second opinion.
So went to check on the heads, and the machinist was able to massage the crack out of the metal. Said it was just a hairline fracture! Nice! He suggested brass Valve stems, anyone here use these?
Said they were worn enough to replace and said it was only a dollar more for brass, which he then said were easier on the valves than the originals. Which I guess brass would be, but I've never used them.. Good idea?
I don't see factory guides worn out with 70K on them. I have seen ones with 170K good to go another 100K... The machine shops will take every penny from you if you let them.
