Could this cam pass emissions?
Old Apr 19, 2018 | 04:50 PM
EmeraldFlame772's Avatar
Default Could this cam pass emissions?
Im selecting a cam for my 4.030 x 3.900 LS build for my 2500 would a 212/218 cam with a 5.49/5.49 lift and a 115+5 lsa pass emissions? I have that sniffer test here in utah
Old Apr 24, 2018 | 01:45 PM
lxcoupe's Avatar
Man Utah is even worse than Cali!
Old Apr 24, 2018 | 02:27 PM
Richardman1992's Avatar
How old is the truck it's going into? 2001 and newer don't require a sniffer test in Utah. But my Comp 212/218 low lift passed in California when I still lived there.
Old Apr 24, 2018 | 03:15 PM
BudRacing's Avatar
That's a pretty mild cam. I would assume it will pass as long as you've got properly sized cats.
Old Apr 24, 2018 | 11:07 PM
Vortec350ss's Avatar
You should be OK. There are some tuning tricks to help too...
Old Apr 25, 2018 | 08:25 PM
Mines a 2001 they did they sniffer on it last time they said half tons don't but 3/4 tons do idk if that sounds right
Old Apr 25, 2018 | 11:43 PM
Where about in Utah are you? I just redid my emissions in January in Davis county and don't recall have a sniffer test done. My 01 is a 1500
Edit: ah my bad I misread that. I didn't know 3/4 ton trucks had to have it done. As long as you still have cats and a good tune it should be fine.
Old Apr 25, 2018 | 11:45 PM
salt lake they said 1500s don't but 2500s do I thought it was odd
Old Apr 27, 2018 | 11:43 AM
How big do you think i could go with a 400ci motor before it wont pass
Old Apr 30, 2018 | 11:21 AM
BudRacing's Avatar
Here's a consideration for anyone contemplating what will/won't pass.
In my metro, if a newly registered auto is brought into the metro testing counties it will be sniff tested upon it's first test. Once it passes the sniff test the first time, it's just an OBDII checkup annually to scan for codes. If you're planning big upgrades on a newly registered vehicle, it's best to get it tested/registered first, and then go for the build.
91Z28
Dec 15, 2011 04:54 PM
Snake Eater
Dec 22, 2006 06:37 PM
chris99gmc
19
Mar 12, 2005 12:23 AM
jeremys
21
Feb 24, 2005 06:29 AM
jnybbad
Oct 25, 2004 10:51 PM
