corner of heads nicked up
Old Feb 11, 2009 | 04:55 PM
GMCtrk's Avatar
Default corner of heads nicked up
I'm assuming this happened during shipping....I know UPS isn't the kindest to heavy packages.
Anyways, on this first one there was a significant amount of metal stickup up on the head surface so I went and ground it off. It feels smooth and flat to the finger, I'm assuming I'll have no problems here?
Second head also had a nick when i opened the box, it's slightly raised on the head surface, I haven't touched this one. Will this cause any sealing problems. I'm using standard GM MLS gaksets btw.
And if you're curious what the stage 1 prc ports look like here's my best attempt at photography
intake port:
exhaust port:
5 angle comp. valve job:
Old Feb 11, 2009 | 05:20 PM
whitegmc2003's Avatar
they look nice but that sucks about the nicks... also is that another scrape on the bottom picture
Old Feb 11, 2009 | 05:27 PM
hirdlej's Avatar
I'd knock those nicks down with a small file. Otherwise those nicks don't even look like they're on the sealing surface of the head. They go onto the deck but there's no water or cylinder gasses near those nicks. Stop worrying.
Old Feb 11, 2009 | 05:28 PM
hirdlej's Avatar
Oh and you worry too much
Old Feb 11, 2009 | 06:13 PM
allballz57's Avatar
are these the heads going on at the GTG?
Old Feb 11, 2009 | 06:14 PM
GMCtrk's Avatar
yes sir
Old Feb 11, 2009 | 06:25 PM
hirdlej's Avatar
How do you install heads at a get together? Is this at a shop? This is typically an 8 hour job if done right.
Old Feb 11, 2009 | 08:27 PM
silver-mod-o's Avatar
Hunt&Fisherator
If you arent messing around, you can do 2 sets in 8 hours.... Its not a hard job.
Old Feb 11, 2009 | 08:32 PM
dlt76028's Avatar
agreed, i had my intake and heads off in under 2 hours.
Old Feb 11, 2009 | 08:50 PM
hirdlej's Avatar
Yeah I here you there, BUT cleaning the gasket material off and plugging all the water jackets and vacuuming out the cylinders and making sure everything is installed to perfection takes time. I guess I'm just slow....
