Compression test #'s
Old Dec 15, 2006 | 03:02 PM
zippy's Avatar
LOL, on 7 cylinders your getting closer to the normal cubic inch range.
Maybe 9.5's next season on normal compression.
Old Dec 15, 2006 | 03:54 PM
MR Marine's Avatar
Gotta have the cubes don't have a power adder
Old Dec 15, 2006 | 03:58 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Any plans to spray it?
Old Dec 15, 2006 | 04:01 PM
zippy's Avatar
I agree fully. Not to mention the big cubes just sound bad ***.
Old Dec 15, 2006 | 07:03 PM
MR Marine's Avatar
I'm collecting parts to fuel inject it and then twin hair driers on it probably a pair of 88's or around there.
Old Dec 16, 2006 | 11:30 PM
eallanboggs's Avatar
I assume those are dry numbers. You should also do the test wet to see how the values change. Compare the dry test numbers to the wet test numbers to figure out if your leakage is on the top or bottom end. You only have to do #5 wet since the others are OK. Top Fuel loses 800 HP when they drop one cylinder so don't feel too bad.
Old Dec 17, 2006 | 09:24 AM
MR Marine's Avatar
#5 is already full of oil the spark plug was soaked when I took it out its definitely rings. Its time to make it tight and right again.
Avalanche2002
Nov 30, 2015 07:31 AM
BlownHD
Oct 3, 2015 12:24 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
