Compression test #'s
Old Dec 13, 2006 | 03:27 PM
MR Marine's Avatar
Default Compression test #'s
When it was put back together 3 seasons ago
200 psi across the board todays compression test
1- 179 2-180
3- 200 4-200
5- 71 6-178
7- 175 8-175
It blew the dip stick out on the first pass last day out, I think I might have a ring seal problem How much power am I losing here??
It ran a new best last pass of the day I think it still has a little left
Old Dec 13, 2006 | 03:57 PM
ZR1 DREAMING's Avatar
Yeah I'd definitely say you've gat a bad ring seal. That sucks man.
Old Dec 13, 2006 | 03:59 PM
MR Marine's Avatar
Its schedule to come apart this winter anyways
Old Dec 13, 2006 | 04:08 PM
ok, that's cool. Are you doing all seals and bearings? Or pistons and more?
Old Dec 13, 2006 | 04:31 PM
MR Marine's Avatar
Rings, coated bearing, anti friction coating on pistons ,ceramic coat piston tops and chambers.
Old Dec 13, 2006 | 04:35 PM
AeroKing's Avatar
is there a chart saying what your compression ratio equals for your compression numbers???
Old Dec 13, 2006 | 04:39 PM
MR Marine's Avatar
I don't know but 200 down to 71 that cylinder can't be doing much. Let alone all the others that were low, and the last pass it still ran a 9.88
Old Dec 13, 2006 | 05:14 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Pretty stout numbers on 7 cylinders
Old Dec 13, 2006 | 05:41 PM
XLR8NSS's Avatar
Adkoonerstrator
Maybe the saying is true, "They run their hardest right before they blow up".
Old Dec 13, 2006 | 07:33 PM
MR Marine's Avatar
I guess that would be true with all the other cylinders that were low would about equal one dead hole.
