compression ratios due to milling heads
Old Nov 5, 2006 | 10:44 PM
Tahoe6.0's Avatar
Default compression ratios due to milling heads
where do I find a chart so I can mill my LQ4 heads to the proper chamber size?i think I want to be at 10.1 to 10.5 ratio on 93 octane. what kind of gaskets for proper thickness also. did a search and range was .030-.55, couldnt get an exact number to mill. Thanks,
Old Nov 6, 2006 | 10:10 AM
Rhino79's Avatar
9 Second Club
Every .006" you mill will subtract 1 cc from your chamber, so .030" would be 5 cc's milled off which would put an lq4 head at about 67-68 cc's. Using the calculator I found, milling .030" and using a .040" thinck gasket would give you your desired 10.5:1. Just do a google search for compression ratio calculator and enter in you combo.
Old Nov 6, 2006 | 05:28 PM
Tahoe6.0's Avatar
Thanks guy,
Old Nov 6, 2006 | 09:36 PM
Grumpy5.3's Avatar
so how thick are stock 6.0 gaskets???
Old Nov 6, 2006 | 09:42 PM
Tahoe6.0's Avatar
.054"
Old Nov 6, 2006 | 09:56 PM
Grumpy5.3's Avatar
so you have to buy cometics to get .040???
figures!!!
Old Nov 6, 2006 | 09:59 PM
Rhino79's Avatar
9 Second Club
Yeah, costs more for friggin head gaskets than to actually mill the heads!
Old Nov 7, 2006 | 06:30 AM
Tahoe6.0's Avatar
I'm going to mill heads for the stock head gaskets accordingly for 10.5 to 1. What will the HP percentage increase be on increasing comp 1 point? With cam and tune? Is it worth it?
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
BIGD4504
Jul 28, 2015 11:46 AM
Aboss
Jul 9, 2015 10:28 AM
