Compression Ratio and Nitrous
Old Nov 13, 2007 | 07:47 AM
TXsilverado's Avatar
Originally Posted by zippy
I'd guess that at about 23º of timing you should be ok.
well see what she takes. TONS of guys on tech are doing it and recomend it so i dont see the problem. im pushing 35-36* timing now so i dont see why it wouldnt make 28* n/a with the 11.0:1 compression.
Old Nov 13, 2007 | 10:42 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I think he was talking about timing on the juice. You should be able to run low/mid 30*s advance N/A. My buddy has a h/c 5.3 at 11:1 and he has bumped the timing up to 36*s before with no problem. Generally you take 2*s of timing out per every 50hp of nitrous. I ran 34*s advance on my old 418 that had 11.2:1CR.
Old Nov 14, 2007 | 01:36 AM
like i said...well see what it takes. this is my first experience with nitrous/heads and higher compression so i dont have any true guestimates. the turd has always taken more timing than expected from the time it was bone stock so i have no clue. the wideband will be hooked up for all tuning.
compression vs timing has been a debate for a while. im not even sure how long i will run nitrous since im more of a N/A kinda guy. ill probably get some glory numbers and ditch it quick cuz im a *****
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
gavin2005
Sep 13, 2015 09:04 PM
