Compression
Old Dec 27, 2011 | 07:20 AM
whitedakota's Avatar
Question Compression
My buddy threw together a 6.0 over the past few days. It consists of a fresh hone, new bearings, stock crank and rods, a set of coated lq9 flat tops, all with stock bolts. Cam is a comp 220/220/114, with a set of home ported/cleaned up 241 heads from his 02 camaro with stock mls gaskets. What kinda compression ratio and power you think this will make?
It's got a built 60e(good clutches, trans go, vette servo, sun shell) stock converter with 4.56 gears.
It's in a 99 ext cab z71 with 33's. Stock exhaust with a borla xr1 exiting in stock location. Stock intake and throttle body and stock air cleaner and tube.
Thanks
Old Dec 27, 2011 | 03:21 PM
im gonna guess 11.5:1?! anybody
Old Dec 27, 2011 | 04:48 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Well the factory 6.0 heads are around 71 cc with the 317 heads and the 241 heads are around a 66 cc
Every 7cc is 1 full point of compression so with around 10:0-1 that would put him around 11:0-1
Gasket thickness and any milling would also affect this.
The LQ9 put out around 345 horse at the fly wheel on a stock tune from the factory so it will easily be over 400 at the fly wheel.
Old Dec 28, 2011 | 07:09 AM
Coban's Avatar
LQ9 with 243 heads (basically an iron LS2) is 11.0:1. 243 heads are 64cc.
LQ9 with 241 heads with 66cc chambers is probably around 10.7:1-10.8:1 according to calcs.
Old Dec 28, 2011 | 07:49 AM
Thanks guys.
Old Jan 6, 2012 | 02:03 PM
bmd_CL's Avatar
7cc per compression point is not always correct, it vary by how high of compression youre actually at. a 16:1 compression engine will change half a compression point with 2cc less combustion chamber...to change an 8:1 compression engine half a compression point it takes 8cc less combustion chamber. not always a good rule to follow
Old Jan 6, 2012 | 02:28 PM
1FastBrick's Avatar
There are several variables to consider but it works for most of this stock stuff. It always best to measure everything for the most accurate number.
walledition
Feb 24, 2026 03:27 PM
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
