Comp Cams adjustable timing chain set.........question
Old Nov 1, 2006 | 05:12 PM
moregrip's Avatar
what a rush!
Default Comp Cams adjustable timing chain set.........question
I recieved my Comp Cams adjustable single timing chain set today and I was wondering if I should upgrade the actual chain to like a JWIS or something.
I'm not all that excited about the chain that came in the kit, if it's comparable to an LS2 then I'm ok with it, the name on the side of it is Renold. It seems quite a few companies use Renold true roller chains.
Thoughts?
Old Nov 1, 2006 | 07:26 PM
moregrip's Avatar
what a rush!
anyone?
Old Nov 1, 2006 | 07:44 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I dont see why you would need to upgrade. Buying a Comp Cam set is already an upgrade from stock.
Old Nov 1, 2006 | 07:55 PM
Bill Reid's Avatar
grippy,
The chain that came with your kit looks good. If you want a known good high quality chain other than resorting to an LS2 chain, which is plenty strong as well, maybe give Katech a shout. I used to buy just their chains and sell them with GM gears... this was before the double setups came out for GENIII... here I go dating myself...
Bill
Old Nov 1, 2006 | 08:23 PM
moregrip's Avatar
what a rush!
thanks guys, looks like cloyes uses the Renold tru roller chain on their timing sets as well, I think I am going to give Katech a shout just for piece of mind
Old Nov 1, 2006 | 09:02 PM
I'm using a Compcams adjustable roller setup,after a years use and about 13,000 miles the chain had stretched enough that it was in need of replacement when I changed cams.I replaced it with another Compcams timing set.
Old Nov 1, 2006 | 09:04 PM
moregrip's Avatar
what a rush!
was this a single or double?
Single.
Old Nov 1, 2006 | 09:11 PM
moregrip's Avatar
what a rush!
Single.
thanks for the info, appreciated
Old Nov 1, 2006 | 09:15 PM
Steve Bryant's Avatar
LS1 Tech Veteran
I'm running the same timing set and it works great.
BTW, look at your cam sprocket. The Comp timing set is a Cloyes Hex-A-Just. It's stamped right on the gear.
Steve
ARC
57
Feb 21, 2022 10:54 AM
chopperloco
Jul 10, 2016 10:45 PM
low2001gmc
Jul 23, 2015 05:10 PM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
