combo suggestions
Old 06-21-2009, 08:32 PM
junk racing's Avatar
Red face combo suggestions
Well i have decided to ditch the 4.3 out of my 03 s10 and do a 5.3 build. I wanted too run my combo by some of the LSX veterans and see what you guys thought as this will be my first ls1 build....here goes
-5.3 im going to freshen it with new bearings and file fit rings, gapped for NOS
-ARP rod bolts, possibly main studs
-TSP 228R cam on 114 LS
-PRC Stage 2.5 heads
-Crane gold 1.8 roller rockers
-PP intake port matched to heads, cleaned up
-86mm tb
-longtubes if they offer them, (havent reasearched this yet)
-built 4L60, red clutches, kevlar band, TCI servos, deep pan, etc.
-yank 3600 converter
-8.5 or 8.8 built 4.10's
i will be spraying it with a 100-200 shot, im not sure how the s10 guys are hooking up on the streets/tracks so i may do a ladder bar setup in the rear, but this will mainly be a street truck
Any tips or things you might change would be appreciated. i will be starting on the motor in about a week.
Thanks
-Donnie
Old 06-21-2009, 08:59 PM
dry_kill's Avatar
me personally i'd save a couple more hundred dollars and put a 6.0. dont forget a UD pulley, elec fans, and maybe a 160* t-stat, bigger injectors, transmission cooler for extra safety, and pretty sure you know this, but just incase you dont, upgraded valve springs and hardened pushrods. hope this helps
Old 06-21-2009, 09:14 PM
The main reason is a friend of mine owns Gearheads out of arlington Tx, he is going to sell me the 5.3 dirt cheap, he has a 6.0 but it needs quite a bit more too be complete....the 5.3 is complete so i chose it.
I knew about all the small things, but i appreciate you helping out, the heads im buying from TSP have upgraded valves, springs and retainers. The truck already has an aftermarket trans cooler.
Thanks
Vortec350ss
01-12-2016 10:36 PM
SSpeeDEMONSS
10-03-2015 08:21 PM
The_W
10-01-2015 02:35 PM
old motorhead
09-29-2015 08:22 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: combo suggestions
