Cleaning a Cam?
Old Nov 19, 2011 | 10:42 AM
InsaneDomestics's Avatar
Question Cleaning a Cam?
Not sure if this is the right place for this post but...
I have a Cam with some slight surface rust, what is the best way to get this cleaned up and make this useable again?
Old Nov 19, 2011 | 11:22 AM
Coban's Avatar
I would treat a cam like you treat clear coat paint... 1500-2000 grit sand paper at most and then find some kind of metal polish and get it to nearly a mirror shine.
Cam lobes are case hardened so take off as little material as possible. You don't want to affect the hardness at all or the lifters will destroy it.
Old Nov 19, 2011 | 01:10 PM
01silvy's Avatar
I would think it it was just surface rust you could let it soak/spray a strong cleaner on it then spray it with wd40 or something similar and wipe it down good with a rag.
Old Nov 19, 2011 | 05:44 PM
99ta's Avatar
A engine machine shop can polish it like a crankshaft. That is what I'd do.
Old Nov 19, 2011 | 08:32 PM
MikeGyver's Avatar
I would take it to a machine shop, too. If they say that they can't fully clean it up, then scrap it. One pit on a cam lobe, or a lifter wheel, or a wheel bearing roller for that matter, and they will self-destruct.
Old Nov 19, 2011 | 10:21 PM
Yeah I went out and had a look at it today. I'm gonna take it to a shop... I wanna get thier opinion and see what they'll do, it's seen better days.
Old Nov 20, 2011 | 01:22 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
To answer your question, when in doubt-throw it out.
Old Nov 20, 2011 | 01:55 AM
06Sierra2's Avatar
i would do the same just to be safe, cams are cheap compared to what could happen...
Old Nov 20, 2011 | 09:24 AM
MikeGyver's Avatar
... when in doubt-throw it out.
Jesse Jackson?
Old Nov 20, 2011 | 02:20 PM
Lmao!
greedygenius
Sep 3, 2015 06:51 AM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
justuc
Jul 24, 2015 11:52 PM
low2001gmc
Jul 23, 2015 05:10 PM
