Catch can bungs with stock truck coils, where???
Old Nov 28, 2019 | 09:49 AM
Resolute_welding's Avatar
Default Catch can bungs with stock truck coils, where???
I've searched for a week now with no luck, is there a good place to mount a 12AN bung on each valve cover in a NBS? It just looks awful cramped on them and I don't want to order everything just to find out it doesn't fit. If I can get away with a 10 an I will, but most everyone suggests 12.
Old Nov 28, 2019 | 11:05 AM
03sierraslt's Avatar
What is your setup that you feel you need two -12?
Old Nov 28, 2019 | 04:52 PM
arthursc2's Avatar
When I get home I'll post some pics of the -10AN on the gen4 covers. The passenger side needed some fab work
Old Nov 28, 2019 | 04:58 PM
End goal is 900hp if possible. Doing my 80e swap now. I'm eyeing an s480 and will end up swapping a forged 5.3 or 6.0 in place of the 4.8. I'm up and running on a 7875 now, but don't want to redo things in the next year or so.
Old Nov 28, 2019 | 05:38 PM
arthursc2's Avatar
I think 10's would do you fine
Old Nov 28, 2019 | 07:40 PM
No reasons you should need dual -12’s, if so you have an issue.
Old Nov 28, 2019 | 09:37 PM
arthursc2's Avatar
Old Nov 28, 2019 | 10:17 PM
Is one of those in the old oil fill Port? Are those both at the front of the motor? If so I definitely like that setup! Especially since y'all are sure I can run 10an lines.
Old Nov 28, 2019 | 10:37 PM
arthursc2's Avatar
I'll take some more photos tomorrow to hopefully clarify.
First pic is a 10AN bung on the PCV boss, rear of the driver head. That's pretty common
Second pic is a fabrication I did to get a 10AN on the passenger side, back of the VC. It's an aluminum tube, 3/4 OD, 1/2 ID. Drilled the cover, coped the tube, welded to cover and welded bung on. I did a ton of test fits to ensure the coils would still fit
Old Nov 29, 2019 | 09:21 AM
If you go this route it’s advised you add baffling by the oil fill as if not it will suck more oil then you want.
