Camaro build
Old Dec 7, 2020 | 06:28 PM
Ben Nicholson's Avatar
Registered User
Default Camaro build
2004 lq4I have a stock 2004 lq4, I have a texas speed 231-234-108 cam and a set of 243 heads milled . 20. My question is should i leave the mill at 20 are go 30? 2. Will flattop pistons clear the valves with either head mill? Are should i stay stock dish pistons. Will be running stock mls head gaskets. Just wanted advice . Any help appreciated. Oh gonna be running a standalone nitrous express crossbar and Gary Williams carb. With springs and pushrods for cam.
Old Dec 7, 2020 | 08:16 PM
68Formula's Avatar
There are plenty of members that can give good advice on here. But since this is going into a Camaro, you'll get a wider breadth of information posting on this site: https://ls1tech.com/
Be sure to include what year (so people can get an idea of your setup), trans, stall (if auto), rear gear ratio, and octane.
Old Dec 7, 2020 | 09:36 PM
arthursc2's Avatar
It's got a solid rear-end, probably body on frame and isn't *that* lightweight
it's basically an aerodynamic, yet less practical truck 😂
Old Dec 8, 2020 | 11:23 AM
TXsilverado's Avatar
PTV clearance depends more on cam events. I had a LS2 with a 237/242 110+4 lsa and had to cut .090 off the intake side to get .072 PTV clearance. I was running aftermarket heads on a different valve angle and larger valves on that combo so your results wont be the same. I say 1: cut the heads to the compression you want 2:put the engine together 3: measure the PTV and go from there. if you need more PTV clearance give lindy tools a call and rent one of their in head flycutting tools.
https://www.lindytools.com/ihpc
sross
Feb 20, 2017 09:33 PM
silvy13
28
Oct 11, 2016 12:55 PM
bcearley
Aug 30, 2016 09:46 AM
silvy13
Jun 2, 2016 02:38 PM
Nicksilverado
Jun 11, 2010 05:40 PM
