6.0 with 799s milled
Old May 29, 2016 | 09:23 PM
silvy13's Avatar
Default 6.0 with 799s milled
Ok guys i pulled the trigger on my build it consists of a lq4 stock bottom end ima be running gm mls head gaskets with 799s milled .30 with 228/232 cam with a NNBS intake what are yalls thoughts on it and i would like to know around what CR this build will be at. i havent seen a build like this.
Old May 31, 2016 | 11:30 AM
silvy13's Avatar
Anyone??
Old May 31, 2016 | 07:20 PM
embs2001's Avatar
I think the compression ratio will be around 10.5 with stock 243 heads on a lq4.
Milled, I dont know, close to 11:1. Kinda just a iron ls2.
Old May 31, 2016 | 08:16 PM
zblee's Avatar
In order to get the CR, you will need to know the chamber size. what is the chamber size after milling the heads? after know this you can use an online calculator
Old May 31, 2016 | 08:59 PM
LJ93Z28GM's Avatar
It would drop to essentially a 706 head chamber, so 61 cc give or take a 1/2 CC
Old Jun 2, 2016 | 12:18 PM
silvy13's Avatar
Thanks guys i just needed a ball part in CR..i been looking for head gaskets but i keep finding different sizes anyone would know what size i would need .51 or .41
Old Jun 2, 2016 | 02:38 PM
slvrram's Avatar
Depends on the compression you're shooting for. There's a calculator on Eagle's website that is way helpful. You really need to volume check your chamber if you want to get accurate numbers. I'd also check PTV depending on the lift of that cam.
01SilveradoJakee
11
May 30, 2016 09:17 AM
Justhereforinfo
Mar 22, 2016 12:41 PM
TAPyvehc93
Mar 20, 2016 11:08 AM
dkutej
Mar 20, 2016 11:02 AM
stroker87
Mar 13, 2016 06:12 PM
