cam swaps
Old May 25, 2018 | 01:51 PM
longbeach420's Avatar
Registered User
Default cam swaps
i need help picking a cam .i want one thats not so loud but packs a punch can anyone help
Old May 25, 2018 | 03:45 PM
FFDP's Avatar
And you drive what?
Need specs on everything here, like vehicle/transmission/gears etc etc. Just a FYI the cam does not make it loud unless you have aftermarket exhaust or something. Slapping a cam in an engine with stock exhaust would still make it sound stock but with a slight lope.
Old May 25, 2018 | 05:58 PM
Registered User
its a 2000 silverado 4.8 i have long tube headers straight pipe wat i mean by loud it a loud lobe i heard sum worh headers and there not so loud as others
Old May 25, 2018 | 06:56 PM
FFDP's Avatar
What kind of goals do you want?
Do you want to run a stall converter with this cam?
In a 4.8 that is rev happy you are likely best to stick with a something in the 212/218 range cam size on a stock stall.
Old May 25, 2018 | 07:52 PM
Registered User
yeah i wanna keep the stock stall .its an everyday driver so my goal is a fast responsive street truck .i also will be replaceing lifter,rods and springs if necessary
Old May 25, 2018 | 07:53 PM
Registered User
212/218 will it lobe loud ? i want a nice mellow lobe
Old May 25, 2018 | 08:09 PM
FFDP's Avatar
You mean lope?
Lobe is what the lifter rides on, on the camshaft. Camshaft have cam lobes. Camshafts can make the car "lope".
The mellow lope can depend on the LSA (lobe separation angle). A LSA of 110 will lope more than a cam with a 116 LSA but the way it act at idle and low speeds could be worse on a cam with a lower LSA number and can be dependent on the cam size.
A 212/218 on like a 113-114 LSA is a very standard cam that several places sell. They work great and will have a mellow idle lope depending on how the tune is setup.
The little 4.8 won't be super fast because it's a small displacement engine with no boost, but expect a 30-50hp bump for sure.
allenp
Nov 2, 2011 11:17 AM
BigRed53
Nov 17, 2006 09:10 AM
NegraRCSB2X4auto
Nov 14, 2006 12:26 AM
GMCtrk
14
Jul 17, 2004 03:10 PM
abbo7
Feb 27, 2004 07:52 AM
