Cam Swap Question
Old Dec 29, 2022 | 08:52 PM
RNC0305's Avatar
Default Cam Swap Question
My truck recently broke down. I took it to the mechanic and told me that the cam and lifters needed to be replaced. My truck had a TR 220-14 but I want to replace it with something similar si ve Thunder Racing is no longer available. Here is the cam that it had.
Old Dec 30, 2022 | 03:08 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Do you know the lift on that cam? I found an old for sale ad that listed 220/220, .552 lift, 114 LSA.
Texas speed has a similar cam but its .600 lift
https://www.texas-speed.com/p-8545-t...-camshaft.aspx
Or if you want to stay around ,550 lift, you could try there stage 3 low lift.
https://www.texas-speed.com/p-8556-t...-camshaft.aspx
Or you could have some one custom grind one for you.
Old Dec 30, 2022 | 10:54 AM
RNC0305's Avatar
Btw my truck has a 3200 stall, I think I’ll go with the low lift since it’s my go to work truck (15 mile drive) what about the lifters. They have this on the website. Would I need to retune the truck?
Old Jan 5, 2023 | 01:30 PM
HawkZ28's Avatar
5 Year Member
If the cams are close in specs, you should be fine. I'd still retune to be safe. You're changing the airflow demands of the engine.
Old Jan 5, 2023 | 05:31 PM
68Formula's Avatar
Even if the duration at 0.050" are the same, the rest of the lobe profiles can be different affecting the volumetric efficiency at different speeds and loads. Not to mention the intake and exhaust centerlines may be different; the ramps symmetrical or asymmetrical. Best to re-tune.
Old Jan 27, 2023 | 09:10 AM
RNC0305's Avatar
Default Update
Just a quick update, my truck got out of the mechanic and now is in need of a Tune since the gears seem to be off.
Old Jan 27, 2023 | 10:36 AM
strutaeng's Avatar
5 Year Member
Huh? What gears are off? 🤔
The timing chain should of been aligned just as before. What is it doing? Missing or misfiring?
Old Jan 27, 2023 | 11:39 AM
RNC0305's Avatar
When I press the gas pedal it won’t respond and the rpm will rev up and then I’ll be to the next gear. I was thinking that it was because it needed to be re-tuned since I did the DOD delete and went with a bigger cam. (My truck was previously tuned before.
Old Jan 27, 2023 | 01:14 PM
shakenfake's Avatar
Shlumpt
5 Year Member
I mean the truck needs a tune but that does not sound right.
Old Jan 27, 2023 | 01:43 PM
RNC0305's Avatar
After a better inspection the electrical tape was around the top boot and nothing was damaged.
