cam swap not going so well.
Old Apr 18, 2006 | 07:46 PM
  #31
FarmerBeau's Avatar
Sexy Party Mod
Originally Posted by mason110
Thats what im thinking, Hes prolly hung up on the journal, wiggle it a little and hold it straight, she should pull out. Like he says the dowel is all the way in, then its not hung on a lifter, Especially if hes seeing lobes out the front of the block.
!COME ON DO IT.....DO IT! Do it.
Old Apr 18, 2006 | 08:09 PM
  #32
Mad_04_chev2004's Avatar
Dude that sounds wrong.
Old Apr 18, 2006 | 09:10 PM
  #33
FarmerBeau's Avatar
Sexy Party Mod
You know....Starsky and Hutch man! "Come on do it!"
Old Apr 18, 2006 | 09:46 PM
  #34
Oh yea, my brain must have stroked off for a second.
Old Apr 18, 2006 | 10:00 PM
  #35
if any thing sounds wrong its the fact your brain stroked off...but thats just me
Old Apr 18, 2006 | 10:10 PM
  #36
hahahaha
Old Apr 19, 2006 | 12:05 AM
  #37
Okie5.3's Avatar
i wound up having to use a 1/4" dowel in the pass side because the 5/16" i had got hung up around #6. does the cam feel like it kind of drops and then gets hung up, or does it just start getting tight? if it feels like it drops, then its hanging on a lobe or bearing journal like everyone has said. just give her a wiggle or two and work it out without banging up a bearing. if it is getting tight you might have to put a little *** in it and twist it on out.
Old Apr 19, 2006 | 06:59 PM
  #38
Joschdog's Avatar
SUCCESS! JPR tool went right in! Cam came right out! Done! Less than 10 minutes! Tomorrow, I'll finish putting the radiator in & fire it up!
Thanks again for all the replies! Now, it's time 4 a
Old Apr 19, 2006 | 07:17 PM
  #39
KySilverado's Avatar
The first cam install I did I had rods in holding up the lifters. Pull the cam out a bit and I hear this clank, clank, clunk. Slide it back in and begin to cuss, knowing I dropped a lifter into the engine and dreading the idea of tearing the engine apart to pull out the darn thing. Get to checking and all the lifters are where they are supose to be.... I'm like WTF. Turns out the free end of the timing chain jarred loose just at that time and dropped down into the oil pan.
Old Apr 19, 2006 | 09:44 PM
  #40
glad to hear you had success, how hard is it really to do a complete cam swap with the engine still mounted?
