Cam swap confusion
Old May 17, 2006 | 07:04 AM
tdrumm's Avatar
Originally Posted by Soon2bSpooled
yea im not really worried about the intake looking stock or not, i found a few on ebay for about 200 bucks used and IMO there isnt much you can do to the intake to make it crappy used unless theres something i dont know. ill need to buy a 90mm throttle body too i think. if you can use the truck fuel rails and injectors and all what makes the install so intensive? if i had a 226 cam installed what rpm should i shift at? 6500? i just dont want to get a cam that rolls all the way up to where i need new rod bolts and all
You can use the truck fuel rails, but they need to have adapters made and new o-rings since they are longer than the car injectors. You can use car injectors and rails if you change out the wiring harness pigtails. The rest of the difficulties involve cutting the alternator braket, relocating the idler pulley, relocating the water pump outlet neck to clear the TB, fabricating an CAI that is lower for the lower car intake, which may or may not clear a mechanical fan shroud.
Search for threads by Kano, he did the swap recently and it came out very nice.
Quik's Avatar
5 year bitches!
why do you say you need a 90mm tb? that may hurt your performance actually if your combo doesnt need it
Old May 17, 2006 | 07:06 AM
Quik's Avatar
5 year bitches!
my 5.3 CAI from K&N didnt need anything but tweaked some to fit into the couplers
Old May 17, 2006 | 11:26 AM
tdrumm's Avatar
Well that is some good info. One less thing to deal with.
Old May 17, 2006 | 09:57 PM
i was just going to get the 90mm because i thought it would be a good idea, i'd be running a 226 .575 114 cam and eventually a 150 wet shot sometime. ill have to search kano's thing. i'd like to do the intake right. keeping the truck fuel rails would be nice but with all the braket and neck and other modifications seems like a pretty difficult job. i wonder how much someone would charge to do all that stuff...
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
SloSVO
Aug 11, 2015 07:33 PM
MS3Z
Jul 30, 2015 06:17 PM
Aboss
Jul 9, 2015 10:28 AM
