cam swap
Old Mar 3, 2006 | 09:40 AM
dropkick13's Avatar
Default cam swap
how much horsepower can you expect from swapping a performance cam?
cost?
Old Mar 3, 2006 | 11:53 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
thats a general statement depends on what size and what motor you have and what other mods you have
Old Mar 3, 2006 | 01:20 PM
dropkick13's Avatar
heh...yea that is rather general.
anyway, i dont know anything about swapping a new cam on. i have the 5.3L with basic bolt ons like intake/exhaust. i would like something that would be a direct swap if possible. so with that little bit of knowledge more, what kind hp you think i would generate and how much would the swap cost? If it REALLY depends a lot on which cam, then i guess just give me an idea of different cams/sizes...thanks
Old Mar 3, 2006 | 08:15 PM
1slow01Z71's Avatar
You willing to put a stall in your trans? That will decide cam choice also. Generally you can expect 35hp IMO with a healthy cam. I put down 330 to the wheels through a t-case in my Z71 with full bolt ons and a tune. I would recommend getting a Nelson tune first before you put a cam in because you will need a custom tune to make it run right. is your truck 4wd or 2wd extended cab or regular cab. I need FULL details of your truck what your goals are, mileage, daily driver?, rear gears, willing ot put a stall in the trans. Answer all that and I can steer you in the right direction.
Old Mar 4, 2006 | 02:20 PM
FarmerBeau's Avatar
Sexy Party Mod
yup. All costs including a good tune, cam, springs, pushrods would be somewhere around or a little over a grand. If you can find some used parts it could soften the financial blow. Here is a writeup on a camswap in an F-body which is damn near the same thing as our trucks.
http://www.ls1howto.com/index.php?article=23
Old Mar 6, 2006 | 05:37 PM
dropkick13's Avatar
2003 5.3L ext cab 2wd 3.73 rear i believe
its daily driver and i would like to hit high 13's with it NA ...trying to keep decent fuel economy too
now...what do i gotta do haha...thanks
Old Mar 7, 2006 | 11:55 AM
kkd60's Avatar
2800 or more stall
beehive comp springs
cam with 215 or more duration
custom tune
Old Mar 7, 2006 | 01:12 PM
ZR1 DREAMING's Avatar
Originally Posted by kkd60
2800 or more stall
custom tune
plus...
e-fans
LT headers
and you should be near your goal
Old Mar 15, 2006 | 01:34 PM
MPFD's Avatar
11 Second Truck Club
I got my comp cam off ebay of $250, it was in perfect shape. My Zo6 springs off ebay for $40. my head were stage 2 ported for $500, and a dacco stall from my local trans shop for $215. Nitrous works system for $360. All I need now is cal tracks and slick and I should be in the high 12's. Thats what I love about nitrous, wanna go faster get a bigger drill bit.
SPRAY FIRST, ASK QUESTIONS LATER!
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
