Need Answer Asap
Old Mar 17, 2006 | 08:25 PM
nochance's Avatar
Default Need Answer Asap
Will Camaro SS HEADS be a good swap for 4.8...Thanks
Old Mar 17, 2006 | 08:44 PM
Not a good swap for a 4.8,you'll loose compression because of the larger chambers and the bigger intake valves will be shrouded by the 4.8s smaller bore size.And unless they are LS6 heads,the ports won't flow any more than your 4.8 heads.Have someone port a set of 4.8/5.3 heads you'll have better results.
Old Mar 17, 2006 | 09:10 PM
nochance's Avatar
Thanks that solve that...
Old Mar 18, 2006 | 08:52 AM
Quik's Avatar
5 year bitches!
SS heads are no different then regular LS1 heads
also i do believe 4.8/5.3 have same bore just different strokes. knowing its teh same block and the block does say 4.8/5.3 right on it.
if you got the heads milled then it would allow you to keep the CR right where you want it but then again stock heads flow well
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
sTNT971
Sep 26, 2015 06:27 AM
MOBBN
Sep 22, 2015 08:07 PM
