Cam swap on '07 5.3L...
Old 08-22-2007, 08:09 PM
  #21
11 Second Truck Club
oh and nothing happens when using a aftermarket cam...oh and the old cams for 99-06 work on this trucks ...
Old 08-23-2007, 01:54 PM
  #22
bhop42's Avatar
So bottom line is you put in an aftermarket cam, unplugged the cam phaser for the VVT, and kept the stock timing chain? Did you use a different timing cover.
Old 08-24-2007, 01:01 AM
  #23
bhop42's Avatar
Sorry I just realized the 5.3 liter didn't come with VVT. Has anybody swapped a cam in the NBS 2007 6.0 engines?
Old 08-26-2007, 04:53 PM
  #24
yeah i know the new 6.0 and 6.2 are diffrent for cam swaps then the new 5.3s and 4.8s ...
Old 09-09-2007, 10:03 PM
  #25
gnd111's Avatar
I have the DOD turned off in my 5.3L Trailblazer.
Old 02-12-2013, 09:25 PM
  #26
jsrunyan79's Avatar
Originally Posted by Diablita
i am getting a cam and heads package installed on my 07 right now and theres like 4 trucks with cam here where i am from already and they all worked with that sproket
Where did you order your cam and heads from I am looking to do the same to my truck and it is a 2011 Sierra.
Old 02-12-2013, 11:12 PM
  #27
10 Second Truck Club
RS/SS 4.8's Avatar
If you are doing a cam swap in a 07+ 5.3 you will need a three bolt cam sprocket with the correct 4x sensor "bumps" the ls2 one for example and you will want to get rid of the dod lifters. The heads will have to come off to replace lifters so get u 4 ls2 lifter trays or 2 depending on milage and ls7 lifters a ls2 timing cover a 07+ 4.8 valley cover and bam reassemble. If you plan on any other mods like boost or n2o get some ls9 head gaskets and arp bolts or head studs and that will take you wherever you want to go. Expensive maybe but if you are putting in a cam with the dod lifters your chancing the risk of lifter failure. DOD is turned off in the tune and VVT as well.
Here is a list for dod delete
https://www.performancetrucks.net/fo...t-list-493773/
BTW this thread is from 07
OHsixLS3
12-27-2016 09:30 AM
GrooveCityZ71
08-31-2015 12:05 PM
WICK3DxGATA
07-21-2015 06:59 PM
Aboss
07-09-2015 10:28 AM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: Cam swap on '07 5.3L...
