Cam swap on '07 5.3L...
#26
Where did you order your cam and heads from I am looking to do the same to my truck and it is a 2011 Sierra.
#27
If you are doing a cam swap in a 07+ 5.3 you will need a three bolt cam sprocket with the correct 4x sensor "bumps" the ls2 one for example and you will want to get rid of the dod lifters. The heads will have to come off to replace lifters so get u 4 ls2 lifter trays or 2 depending on milage and ls7 lifters a ls2 timing cover a 07+ 4.8 valley cover and bam reassemble. If you plan on any other mods like boost or n2o get some ls9 head gaskets and arp bolts or head studs and that will take you wherever you want to go. Expensive maybe but if you are putting in a cam with the dod lifters your chancing the risk of lifter failure. DOD is turned off in the tune and VVT as well.
Here is a list for dod delete
https://www.performancetrucks.net/fo...t-list-493773/
BTW this thread is from 07
GrooveCityZ71
Aug 31, 2015 12:05 PM
GreyChevy
Jul 7, 2015 08:57 PM
