help with 6.0 build
Old Feb 12, 2013 | 04:39 PM
mdabbott2009's Avatar
Default help with 6.0 build
here shortly ill be building a motor for my project truck. im starting with 6.0 form a 2000 truck has the nasty iron heads on it. instead of wasting money on fixing them im going to buy prc 2.5 5.3 heads i belive.
i need help with picking a cam for it and pistons. One i was looking at was a howards cam specs are
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,600-6,600
Intake Duration at 050 inch Lift:218
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:218 int./224 exh.
Advertised Intake Duration:268
Advertised Exhaust Duration:274
Advertised Duration:268 int./274 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.604 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.612 in.
Valve Lift with Factory Rocker Arm Ratio:0.604 int./0.612 exh.
Lobe Separation (degrees):113
Camshaft Gear Attachment:3-bolt
would this work good in a dailey driven 6.0 with stockish stall and what not
thanks for any infomation
Old Feb 12, 2013 | 07:26 PM
craigsix's Avatar
i would be worried about piston/valve clearace with those heads and that lift on the cam.
Old Feb 12, 2013 | 07:28 PM
craigsix's Avatar
i would check into stage one 6.0 aluminum heads.
Old Feb 13, 2013 | 07:58 AM
Thanks I'll have to do some investing. Kinda thought that was gonna be a problem with a set of flat tops
Old Feb 13, 2013 | 12:46 PM
Camin00's Avatar
Great point!
Do you know how to calculate this?
Old Feb 13, 2013 | 12:51 PM
Camin00's Avatar
The specs look great for lowend tq and over all power
If the piston to valve clearance is good
Should work fine with the stock stall
Since your going to have larger ports and big 6.0 cubs I would look into the tbss intake and 90mm throttle body. around 15rwhp more than the stock truck intake.
Old Feb 13, 2013 | 12:55 PM
TXSZ66AVLANCHE's Avatar
PTV will be fine with that cam
Old Feb 13, 2013 | 09:31 PM
i'll make sure to check ptv when putting togeather. Another question what about pistons what would you use for it. speed pro hyper or set it up and gets some mahle pistons? I'm trying to get parts list ready so when it comes time to do it ill just order all at one time.
Do i use ls7 lifters and tray or the crane replacement lifters?
Old Feb 13, 2013 | 10:21 PM
1FastBrick's Avatar
Custm2500's Rude Friend
How about about telling us what type of compression you would like to run???
With the 5.3 stage 2.5 PRC's the largest chamber is a 63cc. Your going to be around 10.9:1 compression ratio.
Do you want to be that high???
If you did the 6.0 heads with around a 70cc chamber you would be in the 10:1 range with a flat top piston. Like a factory LQ9
Old Feb 14, 2013 | 08:22 AM
Thumbs down
We'll I''ll have to run on 91 octane. That's the best I can get into other then e85.
I really don't wanna do that since I don't have flex fuel stuff.
