Cam swap on '07 5.3L...
Old Jun 11, 2007 | 06:47 PM
2006 8.1's Avatar
Just had one of those Active Fuel Management lifters fail on my truck with 6500 miles on it. They had to remove the head and all that to fix it. The tech said that with higher lift cams, you might have an increased failure rate with those lifters. Said that you can't replace them with standard lifters. Not sure if that is true or not. Someone will make a regular lifter to fit them someday.
Old Jun 11, 2007 | 09:30 PM
11 Second Truck Club
i hope it aint true but lets wait and see....what i am wondering is if with diffrent heads everything will change or whats going to happen with the flex/fuel or computer
Old Jun 12, 2007 | 07:24 AM
nighthawk08's Avatar
the heads shouldn't effect anything...what are the cam specs you went with?
Old Jun 18, 2007 | 01:10 AM
LA TOMBSTONE's Avatar
everything is the same u just need the sproket from and 07 z06 ....the sproket on the 07 is a 1 bolt and the z06 one is has the 3 holes for the cam..also with the original spoket u cant make it stay on iven with tunning... nothing gets affected with flex fuel or anything the only problem is that sproket ...the part number for the spoket is: part number: 12586481 and that is it ..
THANKS TO ME
Old Jun 18, 2007 | 11:02 AM
BLACKND's Avatar
I'm assuming none of this would be necessary on the 07 NNBS 4.8 liter. The 4.8 (LY2) doesn't have VVT or AFM or FlexFuel for that matter. I'm considering a small cam swap for my 4.8 but don't want to run into any surprises.
Anyone happen to know the stock cam specs on the NNBS 07's?
Old Jun 19, 2007 | 08:01 AM
Steel Chicken's Avatar
Originally Posted by colyneedsv8
have you tried? It has been confirmed that the profiles are slightly different on 4 of the cylinders, but has anyone actually put in a normal aftermarket camshaft to see what happens?
or did you just say it wont work because you don't think it will?
No. I based my statement upon a very good thread on ls1tech.com where someone posted a GM document specifying details for the DOD cams and additional parts. I didn't just "make it up".
geez.
Old Jun 19, 2007 | 08:53 AM
geez.
ok, but several cars in the valley have cams in 2007 5.3L motors...so you might want to retract your statement?
Old Jul 5, 2007 | 09:12 AM
CHRISPY's Avatar
If I can turn off the DOD in tuning and run a standard ported 5.3 head with the new sprocket cam we should be ok right?
Maybe it'll force us to use a smaller lift/softer lobe cam but that shouldnt be a huge deal.
BTW - I have an 07 5.3 TB
Thanks,
Chris
Old Aug 22, 2007 | 06:30 PM
bhop42's Avatar
Did you guys use the stock timing chain when you swapped out the cam gear?
Old Aug 22, 2007 | 08:02 PM
that 4 cylinder mode should go away with a tune...and u keep ur stock chain everything stock ... just change that sproket and ur ok
