Cam Spec
Old Mar 4, 2018 | 03:36 PM
ss4chad's Avatar
12 Second Club
If you have a ls6 valley cover then make both valve covers your fresh air source, pull your crankcase vac from the valley cover. Hook up a vac gauge and use a restrictor to limit your idle vac to like 3-5”
For reference a stock cam pulls way more vac then your larger cam.
That cam should sound great if tuned right. What’s your hot idle rpm?
Ok, I will do as suggested with regards to hooking up both valves covers with fresh air coming in. According to the link I sent on Post #10, the drivers side valve cover has a "Built In Fixed Orifice Restrictor". That a not a check valve is it? It wont push oil vapors into the passenger side (Clean Side PCV) valve cover will it?
I'm not sure what 'Hot Idle' is, are you referring to the idle after street driving and the temps are at normal operating temps and pressures?
If so then at idle (after street driving, temp. pressure all normal) it is 1100 - 1200 RPMs.
Chad
Saladbar
Jun 30, 2009 07:43 PM
redaddiction
Aug 31, 2004 01:05 PM
cstchevy
Aug 5, 2004 11:05 AM
F8L Z71
May 10, 2004 06:41 PM
99 2500
13
Jan 1, 2004 06:37 PM
