Sierra 5.3 head and cam build
Hello everyone , i have a 2010 5.3L single cab 6L80 sierra
currently running Long tube pacesetter
off road pacesetter y-pipe
Volant cold air intake
magnaflow dual catback and a tune
im looking through doing a head and cam for my truck
i use the truck everyday
no towing no heavy stuff
* the current build im looking at is
* DoD/AFM delete kit from texas speed performance :
16 Chevrolet Performance Lifters (28-12499225)
- GM MLS 5.3L/5.7L #28-12498544
- ARP Head Bolts #46-134-3610
- Include L92 Valley Cover w/o PCV Provision # 28-12598832 (Truck/G8 Applications)
- ARP Crank Bolt #46-234-2503
- Include GM 3-Bolt 4x Cam Gear & ARP Cam Bolts
- Include GM Oil Pan Gasket (28-12612350)
* texas speed dual spring cam package :
- 228R, .600"/.600", 112 LSA
- Change to 110 LSA
- 7.400"
- TSP .660" Dual Spring Kit w/ Two-Piece Seat & Seal, Titanium Retainers, PAC Springs #199-PACPOL660SpringKit
- Rollmaster Single Row Timing Set - 4x Cam Gear (11-CS1190)
- Melling High Pressure Oil Pump (122-MEL10295)
- Include Cam Bolt/Gasket Kit w/ ARP Bolt #28-CamGskKitARP
* About the valves , im thinking of
Manley 2.000 for the intake
Manley 1.600 for the exhaust
* Replace the stock torque converter with Circle D 3200-3400 RPM stall
* Head porting and mill CNC job ( Need help with port and mill specs )
* texas speed long tube 1 7/8 stainless steel headers with y-pipe
* Get a tune
im looking for high rpm power mainly for racing ( Street racing tho no 1/4 drag racing )
Any help , info and recommendation would be helpful !
- Change to 110 LSA
- 7.400"
* Get a tune
Thanks so much for the info ! ill just stick with stock valves and bolts then !
That torque converter....I have a 3000-3200 Circle D in my 4L80E. Just accelerating in traffic, the thing sits at 2500RPM and if I need to get moving, flashes and sits right at 3200RPM. For my daily, it's a little excessive for me. I would go with something below 2800RPM. It's still enough to get the truck moving.
